How can I improve while loop speed on windows?
The being simple doesn't mean it's going to execute fast, I think there is more to optimise in the code inside the loop than anything else.
That said, one thing that might help (again depending on what's in the loop) is to change the while loop for a timed loop to which you can give the highest priority. Also if you have some NI Hardware available you could use the clock as the reference for the loop, but that would probably improve jitter more than raw speed.
  • Thanks 1
In the compiler doc here (https://www.ni.com/tutorial/11472/en/) theres mention of a yieldIfNeeded block which is inserted into loops which allows for coordination with the rest of the runtime. If you just have the one while loop, you are still having to check against the runtime engine if you should keep running or if you need to pause and let other code run. Its not just a simple jump.
tl;dr I dont think there is any way to do this with a regular loop. A timed loop may work. The overhead should be minimal compared to any actual code you wish to run in the loop, and if that isn't true labview is probably not the tool for the job.
Edited by smithd
  • Thanks 1
  On 4/16/2019 at 5:29 AM, LAVA Good said:
How can I improve my while loop speed?
Expand
There are multiple ways actually. Here are a few that come to mind:
  1. Let it run faster by adjusting the code inside the loop accordingly
  2. Split it into multiple loops to utilize more cores of your CPU
  3. Buy a faster computer
Note that there is a limit to how many concurrent threads LV supports: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PARmSAO&l=en-US
And What is the maximum speed in while loop?
Expand
The maximum speed of a while loop is only limited by the speed of your CPU at 100% load (and of course the way your operating system shares the CPU between processes and threads). That is assuming your loop does nothing, which makes it pretty useless. Of course, if your computer has multiple cores, you can run multiple loops in parallel to make use of them.
  On 4/16/2019 at 6:25 AM, LAVA Good said:
Oh my code is simple. I just want to know how to reduce loop speed :) anyway thank you for your reply
Expand
This is contradictory to your first statement. I suppose you mean to increase the loop speed, right?
If your code is simple, it should be easy to optimize for speed or to run multiple instances concurrently if applicable.
Edited by LogMAN
  • Thanks 1
