two while loops one VI
Hello
I have two independent while loops i want to run in one VI
Both loops run continuous tasks such as running a wave form generator or similar
The second one wont start because the first has not "completed"
Is there a way to have two while loops run independent in one VI?
Thanks
To clarify the previous post, the two loops can share a wire as long as that wire is an input to both of them. If the wire is an input from one and an output to the other then the loop that is expecting the input will have to wait for the other loop to output the data.
If you intended to use that wire to communicate data between the two loops, maybe convert the wire between them to a channel wire?
Thanks
Much Obliged
Ill give that a whirl.
I have a few small functions that do some simply things like blink an LED for a status indicator. I cant put them in the main while loop because they onbiously never complete being continuous functions.
Aka the LED never stops blinking so the while loop never iterates. I wanted to put it in its own loop is what i was up to.
I tried to while loops with no wires connected what so ever. They still will not execute independently
Putting a probe on the second while loop still says not executed.
The only thing between them is a single shared variable of type bool
Frustrated that after 2 days i cant get two while loops to execute.
can anyone help?
i am loosing my mind over this
No matter what i do, two totally independent while loops will not execute
they  share only one "shared variable" I can not even comprehend why something so simple is turning out to be so difficult
Make sure you have a Wait node in both loops: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P82BSAS&l=en-AU
Without a Wait node, one loop will consume 100% of a CPU core. This could be why your 2nd loop is unable to run.
13 minutes ago, wannabecontroller said:
still wont run
Post your code. Without it, we can only rely on our crystal ball.
This is what i am doing. Its just a simple state machine example project
The second while loop is calling a sub VI that does nothing but blink an LED on the front panel to show the state machine did initialize
Its more for looks and practice then anything.
It will not execute. I know the VI runs fine on its own. Its been tested
The state machine also runs fine with no issue until i try and make the LED blink
I know this is dumb but i really appreciate the help
Loop 1 in the Main VI
This is the Sub VI in Loop 2, just for an LED blink
This is Loop 2 in the main VI
The Sub VI for blinking LED is the one pictured here
Edited by wannabecontroller
So your subVI contains its own (perpetual) while loop -- is that right? You must understand: A subVI doesn't "finish running" until all of the loops inside the subVI stops. Therefore, Loop 2 in your Main VI cannot continue -- it is blocked because it is waiting for your subVI to "finish running".
You don't need that subVI. Just put all the blinking logic in Loop 2.
Anyway, it is best to post actual VIs, not screenshots. The screenshots might not show important connections.
  • Confused 1
A subvi is nothing more then a function
so because the blinking LED is wrapped into a function labview falls on its face
The reason I am
annoyed and don’t understand what the problem is , to my understanding was suppose to be able to run parallel functions with ease
in your post above you mentioned that as long as they are not wired together they should run independently.
Now you say they are dependent on execution.
 That is not parallel  that is concurrent
Loop1 shouldn’t care what loop 2 is doing.
So essentially creating a sub vi that has a continuous task is useless you are telling me because there is no way to execute it? Is that correct
I thought the whole point of being a good developer was to build re-usable code in the form of functions that can be used over and over. Is that not the case for continuous functions that never complete like  wave form generator or the like
thanks for your reply
In your code, Loop 1 and Loop 2 are parallel and independent as you expect.
Loop 2 not blocked by Loop 1. Loop 2 is blocked by the subVI inside Loop 2.
Yes, a subVI is a function.
But your function does not return, so it blocks the loop!
Not correct.
You can execute your subVI by putting it OUTSIDE of Loop 2.
Edited by JKSH
Thank you for your continued support
Just for kicks i have taken out the SUB VI and just recreated the stuff in the subVI in loop 2.
It runs now
However i have created a new mess that is now causing issue
I have tried to add a few states to the state machine. Of course i broke it.
I will have to post the VI's some how. It is clear i am not understanding this execution.
The state machine works fine with one function. I did not add any new functions just the cases for them and now im back to my initialization loop not running.
