pawhan11 Posted July 10, 2020 Report Posted July 10, 2020 Hello, I ve moved from LV2018 to LV2020 and it seems that position of Clean Up Wire changed from: To:  Can this be changed somehow? I end up creating constants now and have to click multiple times Quote
crossrulz Posted July 10, 2020 Report Posted July 10, 2020 This change happened in 2019. My suggestion is to start getting used to using Ctrl+U to clean up the wires (make sure the wires are selected first). I am pretty sure there is a LabVIEW.ini token to turn this off, I'm just having problems finding it. Quote
Neil Pate Posted July 10, 2020 Report Posted July 10, 2020 @pawhan11 yes this was done because the "data" said that more people create a constant, so it should be at the top of the menu. Truly wish NI would stop f*cking around with stuff like this and fix NXG. There are tokens to turn it off but I have not bothered and instead just learning to get used to it. 2 Quote
