Renny Sadala Posted August 12, 2020 Report Posted August 12, 2020 Hi everyone, I have a myRIO that i try to use to implement a factory pattern of OOP. I have to classes that i need to load dynamically on the VI running in the RT target. Firstly, i saved my classes in the myRIO's memory on the path /home/lvuser/natinst/bin/Host_Class in the directory Host_Class. And i give to the VI "Get LV Class Default Value" this path but i had this error : Error 7 occurred at : Get LV Class Default Value.vi Possible reasons : LabVIEW: (Hex 0x7) File not found. The file may be in a different location or may have been deleted. Use the command prompt or file explorer to verify that the path is correct. ========================= GPIB interface not existing. LabVIEW tried to load the class this way: /home/lvuser/natinst/LabVIEW Data/Host_Class/Accelerometer/Accelerometer.lvclass But when i check this directory, my classes are there Quote
Neil Pate Posted August 12, 2020 Report Posted August 12, 2020 (edited) I am a bit confused. You said you saved the classes to: /home/lvuser/natinst/bin/Host_Class but then you tried to load them from /home/lvuser/natinst/LabVIEW Data/Host_Class/Accelerometer/Accelerometer.lvclass These directories are different... Edited August 12, 2020 by Neil Pate Quote
Renny Sadala Posted August 12, 2020 Author Report Posted August 12, 2020 Sorry, I saved my classes at /home/lvuser/natinst/LabVIEW Data/Host_Class Quote
Neil Pate Posted August 12, 2020 Report Posted August 12, 2020 I have never actually tried to use the factory pattern on a cRIO. So much trouble getting it to work properly just under Windows I have never been brave enough. Do you absolutely have to do runtime instantiation using names? Have you tried a static VI reference? Quote
Renny Sadala Posted August 12, 2020 Author Report Posted August 12, 2020 I'm coding some pretty complex software. That's why I choose the object-oriented approach. And the factory pattern will help to achieve the flexibility that i need. Quote
Neil Pate Posted August 12, 2020 Report Posted August 12, 2020 Sounds interesting. Sorry I have never tried to dynamically load classes in RT, I have enough trouble these days just getting normal code to deploy without stupid un-explainable errors in LabVIEW. For some reason my RT VM is not cooperating and I cannot copy any files across to test. Have you tried to load a very simple class? I presume you have some kind of HAL with inheritance? Maybe the error is because it is missing some dependencies? (I know error 7 is missing file though, as you mentioned). Have you tried loading the class with the 0x10 option? Quote
JKSH Posted August 13, 2020 Report Posted August 13, 2020 5 hours ago, Neil Pate said: For some reason my RT VM is not cooperating and I cannot copy any files across to test. As a workaround, you can transfer files into a USB stick from your host, and then attach the stick to your VM. Quote
Renny Sadala Posted August 13, 2020 Author Report Posted August 13, 2020 I resolved my issue. I must placed my la class file (.lvclass) on the root of the folder /home/lvuser/natinst/bin/ that is the default directory that the RT reads. Quote
Neil Pate Posted August 13, 2020 Report Posted August 13, 2020 I am not sure I follow you. Are you saying an absolute path on RT does not work when trying to load the class from disk? Can you not load the class from the /C/ or similar? That seems weird! Quote
Renny Sadala Posted August 13, 2020 Author Report Posted August 13, 2020 (edited) Previously, i loaded the folder containing my all classes (for example the folder Host_Class). I had placed this folder in the path /home/lvuser/natinst/bin/. I.e I will had /home/lvuser/natinst/bin/Host_Class Now, i place directly my classes in the path /home/lvuser/natinst/bin/ and not via a directory like Host_Class. Apparently, By default, when RT target runs, the reading is limited only to the path specified in the RT target properties. In my case, this path is /home/lvuser/natinst/bin/ Edited August 13, 2020 by Renny Sadala Quote
Jordan Kuehn Posted August 14, 2020 Report Posted August 14, 2020 18 hours ago, Renny Sadala said: Previously, i loaded the folder containing my all classes (for example the folder Host_Class). I had placed this folder in the path /home/lvuser/natinst/bin/. I.e I will had /home/lvuser/natinst/bin/Host_Class Now, i place directly my classes in the path /home/lvuser/natinst/bin/ and not via a directory like Host_Class. Apparently, By default, when RT target runs, the reading is limited only to the path specified in the RT target properties. In my case, this path is /home/lvuser/natinst/bin/ You might check the folder permissions for the folder you created. I have ran into issues with that before. Quote
