Is this a good place to use the "swap value" primitive?
Is it ever conceivable that there will be more than two Queues to monitor?  If so then the last one would scale up better.  That being said it isn't the one I'd find myself using, just because the other two are much more readable.  I'd probably go with the first one.  Swap values is pretty handy when you actually need to swap two values.  Here you aren't really using one of the values.  From a memory or speed perspective I bet you can't measure the small amount of difference (if any) that is taking place.
