Trouble creating an array of objects
I am trying to create a general purpose cDaq program.  It would be used for a variety of measurement types and would have an undefined number of channels.  I would like to use objects.
I am having trouble creating /grouping my objects together without out breaking wires.  Any ideas on what I am doing wrong?  Pics and project below.
Thanks
J--
cDaq_Objects.zip
You are creating an array of objects, then trying to wire that array into a scalar input in your class methods.  An array of objects needs to be handled similar to any other array - you will need to index each object from your array in order to use/operate on them.
  • 1 month later...
You can either have those purple VIs use an explicit array of objects inputs and outputs on the upper corner. However then they are not a class method but simply VIs. Or you can create a new class that has as one of its private data elements the array of objects. Then instead of just appending the objects to the shift register array you call a method of that class to add the object to its internal object array. Then you can make your purple methods be part of that new object collection class.
Edited by Rolf Kalbermatter
