Generating DLL with LabVIEW and call it with LabVIEW
Hi everybody,
I'm generating a DLL with this simple function
I want to recover the clustrer through a DLL function, so i did it in project.
I build the DLL and when i call it, --> TALA CRASH
To recover my cluster i supposed Type is "Adapt to type" and Data format "Handles by Values"
Of course it's not !
Someone know what are Type and Data format of my output should be ?
Thank you,
(i put the VI and project in attached file
test DLL.zipFetching info...
Edited by Youssef Menjour
  On 2/7/2023 at 2:16 PM, Antoine Chalons said:
silly question : does it work if you don't use a cluster in the dll but independent indicators (2 strings, a float and an int) ?
Expand
This example is volontary a cluster for another app. I need a "complexe" structure organized in cluster.
Do you know how to do it ?
