Mahbod Morshedi Posted April 20, 2023 Report Posted April 20, 2023 Hi All, Is it possible use JKI>SMO to generate my classes and then use those classes in DQMH? And also, is it even a good idea to mix and match this way. Cheers, MM Quote
Antoine Chalons Posted April 20, 2023 Report Posted April 20, 2023 Possible : yes Good idea : well... Each framework will bring its scaffolding, resulting in a lot more dependencies, you might no care too much about that. It's more about your context, if you have existing dqmh modules and existing SMOs and want to use a mix for a new project, it could make sense. But if you're mixing the devs need to be proficient with both. Quote
Darren Posted April 20, 2023 Report Posted April 20, 2023 I worked on a project a while back that used JKI SMO for some lower-level functionality and had DQMH modules up top that used the JKI SMO classes. It's definitely possible, and desirable for some teams, depending on the skill level of the team members, their preferred frameworks, and which parts of the application they're responsible for. Quote
Mahbod Morshedi Posted April 20, 2023 Author Report Posted April 20, 2023 Hi All, Thank you for your help and sorry for confusing things on my part. I am only one person and am still very much new in programming. I am a chemistry researcher who does a lot of laser instrumentation. I have developed two applications for my own experiments and am going to developed some more and wanted away to combine them all in one application since they have a lot of communalities. I was wondering if the best way is to use LOOP and to do that, I thought that SMOs give more formulised frame for writing HAL. Then I was going to Use DQMH for the rest of the software (UI, Workup, Representation, Data save, export and import and anything else that requires inter Module communications). I have attached a very rough UML diagram (Please don't judge too harshly I am not a programmer; it is done in PowerPoint and right now). So, I was thinking if it is a good approach or should I stick only to one. Bear in mind that I am using the project to also learn LabVIEW. Cheers, MM Quote
Darren Posted April 20, 2023 Report Posted April 20, 2023 Again, it all comes down to what framework(s) "click" for you. I personally would develop the application entirely with DQMH, here's a very introductory article on how DQMH and HAL concepts work together. Other developers would have great success sticking purely to Actor Framework. Still others with JKI SMO. Learn about the different frameworks, see which one(s) align the best with your mental model, and go in that direction. But whatever you do, don't create a new framework. P.S. - I wrote this article which might also be a good resource for you. Quote
Neil Pate Posted April 22, 2023 Report Posted April 22, 2023 @Mahbod Morshediif you are new to software development then forget about things like OOP and HALs. Just start small and slowly add features. Pick a single framework (DQMH is probably a good place to start) and go slowly. OOP is not the only way to write software, and in fact I would say it generally promises far more than it delivers. The implementation in LabVIEW also comes with its share of "interesting pain points". My advice would be stick to well understood imperative concepts (i.e. just code it as you think, forget about trying to force things into an OO model). Quote
Mahbod Morshedi Posted April 25, 2023 Author Report Posted April 25, 2023 @Neil Pate Thank you Neil, I have already made HAL, I just want to rewrite it (it was my first try and, well, it is messy). But I get your point. Cheers Quote
Mahbod Morshedi Posted April 25, 2023 Author Report Posted April 25, 2023 @Darren Thanks Darren, Indeed, I've checked your HAL implementation. That was my inspiration, but DQMH does not offer tools for generating Objects. That is why I was thinking to make the HAL with SMO and then using DQMH as you have used but I gather it can become even more complicated. Quote
