Byte Array To String Function question
Do you want it in Normal Display format like thsi:
BTW this loop of generating the HEX string is not fast, there are much faster ways of doing it
  • 2 months later...
Could you explain to me what you have done please?
Edited by Lucky--Luka
1 hour ago, Lucky--Luka said:
Could you explain to me what have you done please?
Right click on a string control (or constant) and select "Visible Items->Display Style". The control gets an extra glyph which is marked with the red rectangle in the image of Mikael. This indicates what display mode the control uses.
Note that this changes ABSOLUTELY nothing about the actual bytes used in the string. It only changes how the control displays them!
