Byte Array To String Function question
  • 2 months later...
1 hour ago, Lucky--Luka said:
Could you explain to me what have you done please?
Right click on a string control (or constant) and select "Visible Items->Display Style". The control gets an extra glyph which is marked with the red rectangle in the image of Mikael. This indicates what display mode the control uses.
Note that this changes ABSOLUTELY nothing about the actual bytes used in the string. It only changes how the control displays them!
