PA-Paul Posted March 6 Report Share Posted March 6 Hi I'm trying to install the OpenG Zip package via VIPM. But when it gets to the LVZIP readme page - the "Yes, install this library" button remains greyed out no matter how many times I scroll to the top or bottom of the dialog... It worked fine on a different computer, but on mine I cannot get past this (and its a tad frustrating!). I'm on LabVIEW 2021.0.1f2, VIPM 2023.1 I've tried uninstalling the old version, making sure its not installed in any other LabVIEW version, but I get the same results on any version of LabVIEW... Hoping someone can help! Thanks Paul Quote Link to comment
Rolf Kalbermatter Posted March 11 Report Share Posted March 11 Hi Paul I'm aware of this problem. It has to do with different default fonts in modern Windows machines, which changes the entire text format. The main reason I haven't yet updated the installer was that I was on vacation and there is also a problem to install the package under Linux, which has to do with write permissions to certain file directories. Once I figured that out I will release a new package 5.0.1. Quote Link to comment
PA-Paul Posted March 11 Author Report Share Posted March 11 Thanks Rolf, glad to hear its on your radar already. It's not holding me up in the end as I'm not actively developing anything using the toolkit and fortunately it did work in the place I need it most (the build server!)... but I'll keep my eyes open for the update so I can get it on the dev machines too! Thanks Paul Quote Link to comment
Rolf Kalbermatter Posted April 15 Report Share Posted April 15 (edited) 5.0.1 and in the meantime 5.0.2 has been since released. One issue, but that is not really new and existed before: Don't disable mass compile after install, it may take some time but it sure fixes stale shared library paths in the VI and I have so far not found a way that makes those paths automatically fixup at package creation, since the path seems to need to be absolute. The two possible approaches I'm currently considering: 1) use a so called Symbolic Path (/<user.lib>/_OpenG.lib/lvzip/lvzip.*). Disadvantage: - only works if installed into default location 2) use Specify Library Name on diagram for the Call Library Node and calculate its path at runtime. Disadvantage: - makes the shared library be not a visible component to the VIs, so that the shared library needs to be added explicitly in every application/shared library/assembly/source distribution build in order to be available in such - extra execution time for the dynamic calculation of the path Edited April 15 by Rolf Kalbermatter Quote Link to comment
ShaunR Posted April 15 Report Share Posted April 15 3 hours ago, Rolf Kalbermatter said: I have so far not found a way that makes those paths automatically fixup at package creation, since the path seems to need to be absolute This is why it takes me hours to make an ECL build that works and is one of the many reasons only Windows is now supported (can load from same dir). Even then. I have to fight VIPM to get things in the right places. I refuse to do #2. Quote Link to comment
Rolf Kalbermatter Posted November 11 Report Share Posted November 11 (edited) The problems with the paths to the shared libraries should be fixed with version 5.0.3. It's a combination of using the <library_name>*.* format to let LabVIEW resolve to the right shared library with the first * being replaced with 32 or 64 and the second with the platform specific shared library file extension (dll and so). Also needed to fixup the linker info in the VIs after creating the renamed (with oglib postfix) VI hierarchy through the OpenG Builder functions. LabVIEW, after creating the renamed hierarchy, will store the fully resolved library name into all VIs, which of course is not very helpful as it pins the VIs then to only use the shared library that matches the LabVIEW platform used to create the package. Version 5.0.4 was adding a working low level API for supporting a progress interface to the storing of files into an archive. Version 5.0.5 was adding an extended interface to the Inflate and Deflate functions to compress and uncompress binary streams and control the header used (none, zlib or gzip). Previously only zlib was supported for Deflate and Inflate. Version 5.0.6 fixes a bug when dealing with UNC names that contain numeric characters such as an IP address in the server name. https://www.vipm.io/package/oglib_lvzip/ Edited November 14 by Rolf Kalbermatter Quote Link to comment
ShaunR Posted November 15 Report Share Posted November 15 On 11/11/2024 at 10:06 AM, Rolf Kalbermatter said: Also needed to fixup the linker info in the VIs after creating the renamed (with oglib postfix) VI hierarchy through the OpenG Builder functions. Can the JKI builder be modified to do this? I've already hacked some of their VI's in ogb_2009.llb so it didn't take 6 hrs to build. It's a huge problem for me when building. I have a solution that sort of works, sometimes, but not a full proper solution. Can you detail your process? Quote Link to comment
Rolf Kalbermatter Posted November 15 Report Share Posted November 15 (edited) 1 hour ago, ShaunR said: Can the JKI builder be modified to do this? I've already hacked some of their VI's in ogb_2009.llb so it didn't take 6 hrs to build. It's a huge problem for me when building. I have a solution that sort of works, sometimes, but not a full proper solution. Can you detail your process? There is to my knowledge no way to modify the JKI Builder. Although I think they did fix in recent years a bug that sounded exactly like what I ran across. But the JKI Builder has many other limitations that I'm not fond of so I still rely on my own setup. I basically use ogrsc_builder_3.0.0.11 for the renaming of the VI hierarchy with the opglib prefix with one modifications and then a heavily modified version of the OpenG Package Builder to package everything into the OpenG package. One caveat here, the ogrsc_builder_3.0.0 is from ca. 2009 times (and in 8.6 source code version). It will likely not go well with modern lvclass' and lvlib's and even more likely with lvlibp's files. It does have support for at least lvclass and lvlib but that is most likely fairly unmature seeing when it was last touched. lvclass and lvlib still were fairly new back then and had several quirks even in LabVIEW itself. I changed deep in the belly of the OpenG Builder in OpenG\build\ogb.llb\Copy Resource Files and Relink VIs__ogb.vi, that for shared library names the file name is changed back to the previous <file name>*.* with some magic to detect the 32 or 64 in the file name if present. It's not fail safe and for that not a fix that I would propose for inclusion in a public tool, but it does the job for me. What basically goes wrong is that when LabVIEW loads the VIs, it replaces to magic place holders with the real values in the paths in the VIs in memory and when you then Read the Linker Info to massage that for renaming VIs, you receive these new fully resolved paths and when you then write back the modified linker info you cement the not-platform neutral naming into the VIs and save it to disk. The OpenG Package Builder modifications mainly have to do with a more detailed selection of package content and special settings to more easily allow multi-platform support for shared library and other binary compiled content. In terms of user experience it is the total opposite of VIPM. It would overwhelm the typical user with way to many options and details that it could be useful for most. I had hoped to integrate the hierarchy renaming into the Package Builder too, since the information in the Package Builder would be basically enough to do that, but looking at the core of the OpenG Builder in Build Applciation__ogb.vi will for sure make you get the shivers to try to reimplement that in any useful way. 😁 And yes the naming of the tools is a bit confusing. The OpenG Builder is the tool that massages an existing hierarchy into a new on with VI renaming and relocating them into a configurable tree and fixing up relative paths to be correct for the new names and locations, while the OpenG Package Builder grabs a list of files and simply pushes them into an OpenG package (basically a ZIP file with configuration file). It would be quite useful to integrate the OpenG Builder as an extra prepare step into the OpenG Package Builder but that is a taunting exercise. Edited November 15 by Rolf Kalbermatter 1 Quote Link to comment
ShaunR Posted November 15 Report Share Posted November 15 3 hours ago, Rolf Kalbermatter said: I changed deep in the belly of the OpenG Builder in OpenG\build\ogb.llb\Copy Resource Files and Relink VIs__ogb.vi, that for shared library names the file name is changed back to the previous <file name>*.* with some magic to detect the 32 or 64 in the file name if present. It's not fail safe and for that not a fix that I would propose for inclusion in a public tool, but it does the job for me. What basically goes wrong is that when LabVIEW loads the VIs, it replaces to magic place holders with the real values in the paths in the VIs in memory and when you then Read the Linker Info to massage that for renaming VIs, you receive these new fully resolved paths and when you then write back the modified linker info you cement the not-platform neutral naming into the VIs and save it to disk. The OpenG Package Builder modifications mainly have to do with a more detailed selection of package content and special settings to more easily allow multi-platform support for shared library and other binary compiled content. In terms of user experience it is the total opposite of VIPM. It would overwhelm the typical user with way to many options and details that it could be useful for most. I had hoped to integrate the hierarchy renaming into the Package Builder too, since the information in the Package Builder would be basically enough to do that, but looking at the core of the OpenG Builder in Build Applciation__ogb.vi will for sure make you get the shivers to try to reimplement that in any useful way. 😁 There is a "Copy Resource Files and Relink" in "<program files>\JKI\VI Package Manager\support\ogb_2009.llb" and "<program files>\JKI\VI Package Manager\support\ogb_2017.llb". Is it "Write Linker Info from File__ogb.vi" that you have modified? I'll have to have a closer look. Quote Link to comment
Rolf Kalbermatter Posted November 15 Report Share Posted November 15 (edited) 1 hour ago, ShaunR said: There is a "Copy Resource Files and Relink" in "<program files>\JKI\VI Package Manager\support\ogb_2009.llb" and "<program files>\JKI\VI Package Manager\support\ogb_2017.llb". Is it "Write Linker Info from File__ogb.vi" that you have modified? I'll have to have a closer look. Not quite! It's better to actually modify the Copy Resource Files and Relink.vi. Just add an additional case structure to handle shared libraries. The VI in question is this one: This will unconditionally change the linking name of all shared libraries in your build. There is a possibility that that is not desired although I can't think of a reason why that could be a problem right now. Fixup Shared Library Name.vi Edited November 15 by Rolf Kalbermatter 1 Quote Link to comment
ShaunR Posted November 15 Report Share Posted November 15 25 minutes ago, Rolf Kalbermatter said: Not quite! It's better to actually modify the Copy Resource Files and Relink.vi. Just add an additional case structure to handle shared libraries. The VI in question is this one: This will unconditionally change the linking name of all shared libraries in your build. There is a possibility that that is not desired although I can't think of a reason why that could be a problem right now. Fixup Shared Library Name.vi 31.87 kB · 0 downloads Sweet. It's not quite the same but I'll figure the rest out. You've done the hard part Thanks. Quote Link to comment
Rolf Kalbermatter Posted November 15 Report Share Posted November 15 (edited) 4 minutes ago, ShaunR said: Sweet. It's not quite the same but I'll figure the rest out. You've done the hard part Thanks. I checked on a system where I had VIPM 2013 installed and looked in the support/ogb_2009.llb. Maybe your newer VIPM has an improved ogb_2009.llb. Also check out the actual post I updated the image. Edited November 15 by Rolf Kalbermatter 1 Quote Link to comment
ShaunR Posted November 15 Report Share Posted November 15 (edited) 11 minutes ago, Rolf Kalbermatter said: I checked on a system where I had VIPM 2013 installed and looked in the support/ogb_2009.llb. Maybe your newer VIPM has an improved ogb_2009.llb. Also check out the actual post I updated the image. Yes. The path isn't passed through but I figured out what it was supposed to be. this is the one in my installation: It's a trivial change though. The important part is the adding the extra case and your new VI. I was about to go all Neanderthal on the "Write Linker Info" before you posted the proper solution. Edited November 15 by ShaunR Quote Link to comment
Rolf Kalbermatter Posted Tuesday at 11:48 AM Report Share Posted Tuesday at 11:48 AM On 11/15/2024 at 4:46 PM, Rolf Kalbermatter said: This will unconditionally change the linking name of all shared libraries in your build. There is a possibility that that is not desired although I can't think of a reason why that could be a problem right now. It just occurred to me that there is a potential problem. If your DLLs are always containing 32 in their name, independent of the actual bitness, as for instance many Windows DLLs do, this will corrupt the name for 64-bit LabVIEW installations. I haven't checked if paths to DLL names in the System Directory are added to the Linker Info. If they are, and I would think they are, one would have to skip file paths that are only a library name (indicating to LabVIEW to let the OS try to find them through the standard search mechanism). This of course still isn't fail proof: DLLs installed in the System directory (not from Microsoft though) could still use the 32-bit/64-bit naming scheme, and DLLs not from there could use the fixed 32 naming scheme (or 64 fixed name when building with VIPM build as 64-bit executable, I'm not sure if the latest version is still build in 32-bit). Quote Link to comment
ShaunR Posted Thursday at 10:11 AM Report Share Posted Thursday at 10:11 AM (edited) On 11/19/2024 at 11:48 AM, Rolf Kalbermatter said: It just occurred to me that there is a potential problem. If your DLLs are always containing 32 in their name, independent of the actual bitness, as for instance many Windows DLLs do, this will corrupt the name for 64-bit LabVIEW installations. I haven't checked if paths to DLL names in the System Directory are added to the Linker Info. If they are, and I would think they are, one would have to skip file paths that are only a library name (indicating to LabVIEW to let the OS try to find them through the standard search mechanism). This of course still isn't fail proof: DLLs installed in the System directory (not from Microsoft though) could still use the 32-bit/64-bit naming scheme, and DLLs not from there could use the fixed 32 naming scheme (or 64 fixed name when building with VIPM build as 64-bit executable, I'm not sure if the latest version is still build in 32-bit). I've modified your sub vi to check the actual file bitness (I think). If you target user32.dll, for example, the filename out is user32.* - which is what's expected. I need to think a bit more about what I want from the function (I may not want the full path) but it should fix the problem you highlighted (only in Windows ). Fixup Shared Library Name.vi Edited Friday at 10:40 AM by ShaunR Quote Link to comment
