Common Error and Fix - LabVIEW caught fatal signal
Jim Kring
  • 11 months later...
  • 13 years later...
On 9/21/2020 at 1:11 PM, Suquen said:
Hi Jim Kring,
Would you post the solution here? cos, the link seems expired!!!
Thanks.
Are you using LabVIEW 7.1????? If you use a newer version this should not fix any problem as this specific problem was actually fixed in LabVIEW 7.1.1. The problem was that the LabVIEW enumeration of directory entries assumed that the first two returned entries were the . and .. entries. Since LabVIEW 7.1.1 the Linux version doesn't have that assumption (the Windows version still had at least until recently and that can cause different problems when accessing a Samba mounted directory).
