Jim Kring Posted December 20, 2005 Report Share Posted December 20, 2005 I am doing an operation on a VI using VI server. I would like to change the VI's modification bitset to show as changed, so that that user is prompted to save the VI when it is unloaded from memory (and also the VI Name in the window title should have an "*" to indicate that it has been modified). I have experimented with "Begin Undo Transaction" and "End Undo Transaction" and calling these is not enough to cause a "modification". Anyone know a good way to do this? Thanks, Quote Link to comment
jpdrolet Posted December 20, 2005 Report Share Posted December 20, 2005 I am doing an operation on a VI using VI server. I would like to change the VI's modification bitset to show as changed, so that that user is prompted to save the VI when it is unloaded from memory (and also the VI Name in the window title should have an "*" to indicate that it has been modified). I have experimented with "Begin Undo Transaction" and "End Undo Transaction" and calling these is not enough to cause a "modification".Anyone know a good way to do this? Thanks, When you open the VI reference, do you set the option mask 0x01? From the Help: 0x01 Record modifications. An asterisk (*) appears by the VI title to indicate that changes have been made using VI Server. The VI must be in edit mode for LabVIEW to record the modifications. If the change you made is still not enough, you could simply rewrite the VI Description property or something like that. Quote Link to comment
Jim Kring Posted December 20, 2005 Author Report Share Posted December 20, 2005 When you open the VI reference, do you set the option mask 0x01? From the Help:0x01 Record modifications. An asterisk (*) appears by the VI title to indicate that changes have been made using VI Server. The VI must be in edit mode for LabVIEW to record the modifications. If the change you made is still not enough, you could simply rewrite the VI Description property or something like that. That does the trick! Thanks Quote Link to comment
Rolf Kalbermatter Posted December 21, 2005 Report Share Posted December 21, 2005 I am doing an operation on a VI using VI server. I would like to change the VI's modification bitset to show as changed, so that that user is prompted to save the VI when it is unloaded from memory (and also the VI Name in the window title should have an "*" to indicate that it has been modified). I have experimented with "Begin Undo Transaction" and "End Undo Transaction" and calling these is not enough to cause a "modification".Anyone know a good way to do this? Thanks, I usually do this by toggling the debugging flag twice. Snooped it from some LabVIEW internal functions some versions ago. Rolf Kalbermatter Quote Link to comment
Jim Kring Posted December 21, 2005 Author Report Share Posted December 21, 2005 I usually do this by toggling the debugging flag twice. Snooped it from some LabVIEW internal functions some versions ago.Rolf Kalbermatter Rolf: How do you do this? I could not find a VI property with a name such as "debugging". Thanks, Quote Link to comment
Rolf Kalbermatter Posted December 23, 2005 Report Share Posted December 23, 2005 Rolf: How do you do this? I could not find a VI property with a name such as "debugging".Thanks, Oops is that one of the super secret VI properties? Nope doesn't seem! It is in Execution->AllowDebugging. Rolf Kalbermatter Quote Link to comment
CRoebuck Posted July 5, 2006 Report Share Posted July 5, 2006 When you open the VI reference, do you set the option mask 0x01? From the Help:0x01 Record modifications. An asterisk (*) appears by the VI title to indicate that changes have been made using VI Server. The VI must be in edit mode for LabVIEW to record the modifications. If the change you made is still not enough, you could simply rewrite the VI Description property or something like that. Anybody know how to unset the modification bitset. I have a vi that traverses a vi's heirachy and saves each vi for the previous version of LV. In this case I am reverting to 7.1 from 8.0.1 due to a serious bug found when using TestStand 3.5 and LabVIEW 8.0 RunTimeEngine. My vi runs fine but when I first open the newly reverted vi's using LV 7.1 the asterix is displayed and the vi thinks it's modified. I could just mass compile using 7.1 but I'm curious how to do it at the same time as the vi is reverted. Thanks Chris Quote Link to comment
CRoebuck Posted July 5, 2006 Report Share Posted July 5, 2006 Anybody know how to unset the modification bitset. I have a vi that traverses a vi's heirachy and saves each vi for the previous version of LV. In this case I am reverting to 7.1 from 8.0.1 due to a serious bug found when using TestStand 3.5 and LabVIEW 8.0 RunTimeEngine. My vi runs fine but when I first open the newly reverted vi's using LV 7.1 the asterix is displayed and the vi thinks it's modified. I could just mass compile using 7.1 but I'm curious how to do it at the same time as the vi is reverted.Thanks Chris Ok I now understand why it's doing this. Baiscally the diagram is created for the previous version but not re-compiled for the previous version. D'oh ! Quote Link to comment
LAVA 1.0 Content Posted July 5, 2006 Report Share Posted July 5, 2006 Did you see the ultimate LabVIEW Geek questions for this week (6) If you save a VI to a previous version, and then open the saved VI in that previous version, why does LabVIEW add an * next to the VI name, indicating that there are unsaved changes? (Correct answer worth: 30 points) The new version removes the block diagram and the compiled code so the old version can rebuild it from the machine code only The new version compiles the old version, but it can't actually save the block diagram in the correct form for the old version The new version can write the block diagram in the correct form for the old version, but it can't actually compile the old version Prove your geekiness NOW! :laugh: Quote Link to comment
Rolf Kalbermatter Posted July 5, 2006 Report Share Posted July 5, 2006 Did you see the ultimate LabVIEW Geek questions for this week (6)If you save a VI to a previous version, and then open the saved VI in that previous version, why does LabVIEW add an * next to the VI name, indicating that there are unsaved changes? (Correct answer worth: 30 points) The new version removes the block diagram and the compiled code so the old version can rebuild it from the machine code only Wow LabVIEW contains actually a reverse compiler . Now everyone that saves his VIs with password or no diagram at all is simply buggered ;-) The new version compiles the old version, but it can't actually save the block diagram in the correct form for the old version Hmm, not sure how that differs from the first really. Still needs a reverse compiler and I just so much like this new extraSuperSecretTool. The new version can write the block diagram in the correct form for the old version, but it can't actually compile the old version Naaa! This last one is to simple. It can't possibly be this! ;-) Rolf Kalbermatter Quote Link to comment
