How to prevent the Screensaver from starting
Hello all,
I would like to have my application generate some sort of windows event that will stop the screensaver from starting up. I have tried generating mouse movements but this does not seems to work. Any ideas?
You can programmatically disable the Screen Saver by calling the SystemParametersInfoA function from the User32.dll. Look this function up on MSDN.
post-311-1159975498.png?width=400
Note all parameters are of type U8.
Regards,
-Khalid
Regards,
-Khalid
1- I can't make it to work, could you send me a VI?
2- Where did you get the 17 = SPI_SETSCREENSAVEACTIVE?
Hello all,
I would suggest to look into the .NET framework, i be;ieve you will find something there. Or you could use the attached VI to change the timeout of the screen saver to a maximum of 9999 minutes.
Download File:post-731-1160055219.vi
I am finding that none of the proposed methods will work in my case. The screen saver in question is apparently network administered and designed not to be foiled. It's purpose is to force a login prompt if the computer is not used for 1800 seconds. The screen saver settings appear to be locked. I have even tried some registry hacks but they do not stick. I had assume there would be some way to fake user activity but ordinary mouse and keyboard events do not work.
...is apparently network administered and designed not to be foiled.
...and there is your answer! Looks like need to talk to your administrator :) Depending on company policies, admins are usually not keen to completely remove the station locking, but if given a good reason (it screws up my experiment because the data acquisition stops and I loose my data) they'll often help you out by increasing the time to the lock.
Hi Sachsm,
I asked the same question in this thread
http://forums.ni.com/ni/board/message?boar...d=114553#M52654
about three years ago. None of the posted replies worked for me but there maybe something there that can help you.
Ben
If I had a time machine and a license to kill....
There are two people I would chase down.
The person who decide that men should shave
and
the person who invented computer viruses.
We have the same problem in our company. These settings are usually controlled thru registry settings that are manipulated remotely. We wrote a some vbs code to defeat this practice. It uses the registry key: HKEY_CURRENT_USER\Control Panel\Desktop\screensaveactive",iScreenActive,"REG_SZ. Did you try this?
Andrew
  • 3 weeks later...
  • 1 year later...
