Amplifier in LabVIEW
alnaimi
Hi all,
is there is any icon for amplifer in LABVIEW???f so can u plz help me in that????
Check the sound VIs (search the palettes for "sound"). There's the traditional "volume" icon. The only other icon would be a sinewave getting larger.
hi all ,
thnx for reading my topic in this great forum , actuallly its my main source of learning LABVIEW....
I have question where can I find amplifier in LABVIEW??????????????????
hi all ,
What do you need, your previous question gave you a valid answer.
Please, be more specific and show what you have already!
Ton
thnxxxx so much that helped me alot ,,, But question how can I use the ICon in the indicated example that U told, It can not be copied.. some thing else some ember here put the multiply icon!!!!that is not amplifier?
I'll try two things:
1. The attached VI has an icon with the graphic I suggested before. Use it if this is your problem.
2. You may be looking for a way to increase the values of a waveform. You can do this a couple of ways. A waveform is a series of y values with a constant time, delta t.
The example of the multiply function is actually valid. post-181-1164910392.png
You can also 'attenuate' by dividing or subtracting a value from the waveform.
You connect your waveform to one terminal and the value you wish to use to scale/offset each waveform y value to the other. The output terminal will contain what a modified waveform. Look for Waveform Scale and Offset under "Functions -> Programming -> Waveforms -> Analog Waveform"
Hope this helps, and best of luck....
