LabVIEW 8.20 projects won't open
konroh
Hey Guys,
I did some searching around the forum and at NI.com and didn't see anyone else that had posted about this...if anyone has please direct me to the thread...
Yesterday I created a LabVIEW 8.20 project based on an old 7.1 program I had been working on. Everything was fine. At the end of the day I made sure everything was saved, and all seemed fine. Today when I came in I loaded up LabVIEW, went to open my project...and... nothing...LabVIEW just closes, no error, no prompt...and it does it for any project file I have created. I can open the VIs for my projects just fine, but anytime I try to open a project LabVIEW just disappears. Everything was working fine yesterday afternoon...
Any idea how to fix this?!?
Thanks!
Doug
I am not sure, but read somewhere about deleting your labview.ini file....
(make a backup though)
Ton
Just tried that...closed LV, deleted LavVIEW.ini, restarted LV, still can't open any projects :(
I am still getting the exact same behavior...
I had similar behaviour for one specific project a while back. I never figured out what was wrong. You may try the following. Open LV and create a new VI. Then close all windows visible such as tools, context help, all functions palette, controls palette etc. Last close the VI. Then try opening the project.
Hi Doug - can you post your project file (it's just XML)? It's possible that a file that it's looking for is missing, but that shouldn't crap out LabVIEW...
Hey Chris - the problem is occurring with all my project files...so I think it's definately something with my installation of LabVIEW. I am going to reinstall if I can't figure it out soon, and hopefully that will fix it, but I would like to know what happened so I can avoid having it happen again in the future...
Jimi - tried what you suggested - no change. It's strange, since I can work with individual VI's, but as soon as I try to open a project, LV is instantly gone, no warnings or errors or anything...and it was working perfectly at 5:00 last night when I shut the computer down.
Ahhh that's the issue, you didn't listen to the 'Computer Union' Now they are coming back at yah....
Still sucks though
Ton
Well, for now I am going to try to re-install when I get time...I have been pretty busy today! I'll let you guys know if it fixes the problem. Thanks for the help!
You never did post the .lvproj file. Might be something wrong in the XML. Might be fixable.
I've had the same problems working with lvclasses.
To solve this, I had to open open one of the classes direct (dubble click on the .lvclass file).
Resave it and restart LabVIEW.
The problem I've had is that I don't know which lvclass file to open, LabVIEW crashes when I open
the wrong file.
The problem is caused by using public typedefs from other classes in a lvclass.
But there is soon a solution for these problems ...
//Mikael
Well, now the problem appears to be with MAX and with LabVIEW. And I am thinking it was MAX all along When I open MAX, and try to expand a tab (Software, Data Neighborhood, etc...) I get a dialog saying "MAX Database Connection Error"...I searched on ni.com and found 2 possible solutions, neither worked, so now I am going to search here. I already re-installed MAX once, but it didn't fix it. This time I am going to remove everything, then delete the National Instruments folder in Program Files, and then re-install. Anything else I should try first?
Thanks!
The problem seems to be happening with every project I have, so I doubt they were all somehow corrupted at once. See above, it seems I have a MAX problem, which I am guessing broke my projects...
ok...all is working now...I found on the NI forums, someone said to just delete the data folder in max, then restart the computer...you lose any custom tasks or channels, but at least everything opens now! So reinstalling everything was a big waste of time, but at least I know now...and projects open just fine now. Apparently projects are tied closely to MAX, but you would think an error would appear letting you know why LabVIEW just disappeared!
Anyway, thanks for all the help guys! I appreciate it!
Where on the NI Fourms was it? Was it in the bugs area, or just some random thread? It might be a good idea to put a link to this thread from the bugs area to try to get a CAR# for a fix.
