hannibal Posted December 26, 2006 Report Posted December 26, 2006 Hi. I am new to LabView. I have to design a circle which can show the direction (such as: North, South, South West,...) and the needle which can move like the picture I upload. I use the Gauge Control but the max and the min line has a distance, therefore it can't display all the direction. Can you suggest some ideas for me? I really appreciate your help. Quote
Jeffrey Habets Posted December 26, 2006 Report Posted December 26, 2006 hannibal said: I have to design a circle which can show the direction (such as: North, South, South West,...) and the needle which can move like the picture I upload.I use the Gauge Control but the max and the min line has a distance, therefore it can't display all the direction. Can you suggest some ideas for me? I really appreciate your help. You can grab the max value line of the scale with your mouse and pull it towards the min value. You get a gauge that does 360deg this way. You can also grab the min value to rotate the entire scale. This could be usefull if you want the 0/360 value at the top instead of at the bottom of the gauge. Quote
Grampa_of_Oliva_n_Eden Posted December 26, 2006 Report Posted December 26, 2006 Jeffrey Habets said: You can grab the max value line of the scale with your mouse and pull it towards the min value. You get a gauge that does 360deg this way.You can also grab the min value to rotate the entire scale. This could be usefull if you want the 0/360 value at the top instead of at the bottom of the gauge. You may want to take a look at this thread http://forums.ni.com/ni/board/message?boar...id=83435#M93182 on the NI forum where we finish this up with text markers for N-S-E-W Ben Quote
hannibal Posted December 27, 2006 Author Report Posted December 27, 2006 Thanks Jeffrey. I tried and that's cool. Thanks Ben for your detailed instructions. I can directly make use of your .vi to my project. Quote
Norm Kirchner Posted January 10, 2007 Report Posted January 10, 2007 Will any of these help you out? see attached image Quote
Grampa_of_Oliva_n_Eden Posted January 10, 2007 Report Posted January 10, 2007 njkirchner said: Will any of these help you out?see attached image Is that a semi-transparent needle? Yes it is! Cool. Are you going to share? Ben Quote
Yair Posted January 10, 2007 Report Posted January 10, 2007 Ben said: Is that a semi-transparent needle?Yes it is! I believe that's a numeric with a transparent background placed on top of the needle, which is not transparent. Quote
hannibal Posted January 10, 2007 Author Report Posted January 10, 2007 Hey, your front panel is exactly what I need. Can you show me your block diagram? Thanks in advance. Besides I must create it as an internet website. Now I do not know how to do. Can you give me some materials for me to reference? Thanks much. I must design it through LAN first and then via the Internet. That's still the problem for me. So I appreciate all your help. Quote
Norm Kirchner Posted January 10, 2007 Report Posted January 10, 2007 Funny that you should mention that. This was actually the front end of a web based weather monitoring station driven totally by the LV internet toolkit web server. I could recall historical data too, although it took a bit more. I'll see what I can drum up, but the directional control was based on a customized control w/ 4 floating text decorations. Quote
hannibal Posted January 11, 2007 Author Report Posted January 11, 2007 Hey that's fun. So I need more help from you. 'Coz I don't have any skill about that. I try to create something like that. I also have a task to design a virtual weather station. Could you send me that VI or some instructions to program and design it?Could you recall it? Thanks in advance. Quote
