unlimited queue size
Hello all,
if I see an unlimited queue size, I think LV must realloc the memory every operation with this queue. Now I ask me, its only if the size is unlimited or the memory will be reallocate if the size is definied?
If the memory will be reallocate, its more more slower as the "normally" queue in other programming languages.
Eugen
CITATION(Eugen Graf @ Mar 29 2007, 09:27 PM)
Hello all,
Eugen
Good question... If I was at work I would test it on different computers to see if the Q size is actually unlimited !
I am interested in the answer and the reasons... :book:
As I understand it, queues will dynamically allocate memory, but free memory only when destroyed. The online help states:
Note max queue size only limits the number of elements in the queue. It does not preallocate memory. Enqueue the maximum number of elements and flush the queue to preallocate the queue. The queue reserves more memory as its size increases and releases that memory only when you destroy the queue.
I almost always create my queues as part of my application startup using a fixed size, immediately populate them with dummy data (to reserve the memory) and then flush the queue.
I think allowing a queue grow to unbounded is "asking for trouble".
QUOTE(LV Punk @ Mar 30 2007, 01:50 PM)
Thank you very much for this information.
Do you do it in a for loop? So in your initialisation step? Can you post an exapmple? Thanks
Its right.
Eugen
QUOTE(LV Punk @ Mar 30 2007, 06:50 AM)
It could be a problem, but it's absolutely amazing how often it works just fine. CPUs are fast enough compared with various bus speeds that the dequeue loops for most apps I've seen -- particularly for data aquisition stuff -- are way faster than the enqueue loops, so the queues stay small.
  • 4 weeks later...
QUOTE(LV Punk @ Mar 30 2007, 07:55 PM)
Thanks, but it's only for "string" queues. If I have a queue of other datatype I have to adapt your BD to my type. Are there any possibility to adapt the data type(e.g. by variant), I can use this VI for every queue?
Eugen
QUOTE(LV Punk @ Mar 30 2007, 01:55 PM)
It is far from being evident that LabVIEW keeps the strings data in the queue. While it can keep as many as string handles as the queue size, I doubt it keeps the data itself in the queue but just place holders for handles. I would think it is the same for variable length data like arrays and variants. On dequeuing, does LabVIEW copy the string to the caller (keeping an copy internal to the queue) or just pass the string handle?
QUOTE(jpdrolet @ Apr 25 2007, 03:14 PM)
Allthough I don not know it, I'd bet that enqueuing / dequeuing is a *call by reference* operation. I can't see any sense for duplicating the data, just for the purpose to hand them over to an other function without any modification. And I can not imagine how to implement polymorphic behaviour on a primitive without pointer operations ...
