alnaimi Posted May 5, 2007 Report Posted May 5, 2007 Dear all , I am tryiing to draw I versus VDS for transistor MOSFET 2N7000 , I have made the labview program to draw three curves or more by varying VGS , which is the signiture of the transistor , the proeblem that i am getting only the first curve well , but the others are not drawn well . My circuit out side is included in the attached file . could you please check my VI ? what is the problem ? I apprecaiate ur help .. Quote
i2dx Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(alnaimi @ May 4 2007, 12:39 PM) no one hmm ... sorry, I know quite nothing about simulating electronical devices ... so it's hard to understand what's going on ... Quote
Dirk J. Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(alnaimi @ May 4 2007, 12:39 PM) no one Maybe because your VI is broken (the KI AO xxxxx, and KI AI xxxx VI's are missing) But, if I replace the KI AI Sample Channel VI with some simulating VI, I just get 3 graphs, so I can't reproduce your image.... Quote
alnaimi Posted May 5, 2007 Author Report Posted May 5, 2007 it is not broking there are there ! but what do u mean by simulating |! Quote
Dirk J. Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(alnaimi @ May 4 2007, 01:20 PM) it is not broking there are there !but what do u mean by simulating |! they are there on your system, not on mine. simulating is just replacing the missing KI AI Sample Channel with some number-generating VI in order to build the graphs. Quote
alnaimi Posted May 5, 2007 Author Report Posted May 5, 2007 simulating is just replacing the missing KI AI Sample Channel with some number-generating VI in order to build the graphs. ??? what is that !! i am using only one channel !! Quote
Ton Plomp Posted May 5, 2007 Report Posted May 5, 2007 Hello Alnaimi, Here's my first problem: http://forums.lavag.org/index.php?act=attach&type=post&id=5725 I just don't get the 2D X-axis data? (And why the Iout on the X-axis?) I think this is what you should do: http://forums.lavag.org/index.php?act=attach&type=post&id=5726 This is an example where the online help of XY-graphs could have helped you straight away (ctrl-H and hover over the terminal). Ton Quote
alnaimi Posted May 5, 2007 Author Report Posted May 5, 2007 i did not solve my problem ! sorry dear plz help me Quote
Ton Plomp Posted May 5, 2007 Report Posted May 5, 2007 Ok so what is the problem, please show your code with my solution applied! Ton Quote
Dirk J. Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(alnaimi @ May 4 2007, 01:46 PM) simulating is just replacing the missing KI AI Sample Channel with some number-generating VI in order to build the graphs. ??? what is that !! i am using only one channel !! alnaimi, stop shouting. 1) I do not have your KI AI Sample Channel available. 2) I replaced it with some code to generate one value each time that VI was called. See the attached file. Quote
alnaimi Posted May 5, 2007 Author Report Posted May 5, 2007 QUOTE(Dirk J. @ May 5 2007, 01:52 AM) alnaimi, stop shouting.1) I do not have your KI AI Sample Channel available. 2) I replaced it with some code to generate one value each time that VI was called. See the attached file. what is the disable and enable ?? I did not understood what u added !?? Could u explain and what I choose disable or enable? ********************************* Ton : About ur solution it gave me the same as the prevouis graph ! it did not solve the problem thnxxx dear 4 ur help .. About I yes it should be in Y axis . Quote
eaolson Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(alnaimi @ May 4 2007, 02:43 PM) what is the disable and enable ?? I did not understood what u added !?? Could u explain and what I choose disable or enable? He added structures to turn off the AI and AO VIs that you didn't include with Three.vi. There's also some code to generate some numbers since we don't have your DAQ hardware. QUOTE About ur solution it gave me the same as the prevouis graph ! it did not solve the problem What exactly is the problem? The program compiles and plots lines in the graph. You've never really said what the program should be doing that it's not doing. Quote
alnaimi Posted May 5, 2007 Author Report Posted May 5, 2007 AHaaaaa , I seee but I have already tested those VI's , it did not work with me !! I am claiming LAVA experts to help pleaseeeee. Quote
Mikkel Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(eaolson @ May 4 2007, 10:47 PM) What exactly is the problem? The program compiles and plots lines in the graph. You've never really said what the program should be doing that it's not doing. This, or something like it, could be the source of the problem: http://www.ee.washington.edu/faculty/darling/eefacrbd/EE331LE3rev6.pdf' target="_blank">http://www.ee.washington.edu/faculty/darli...E331LE3rev6.pdf Alnaimi, is this a school assignment? -Mikkel Quote
eaolson Posted May 5, 2007 Report Posted May 5, 2007 QUOTE(alnaimi @ May 4 2007, 03:49 PM) I have already tested those VI's , it did not work with me !! Again, what does "it did not work" mean, specifically? I would suggest first checking by hand with a voltmeter to make sure your circuit is working properly. The best LabVIEW in the world won't help you if your transistor is fried or if you have a loose connection. Then check to see if your AI/AO routines are working properly. Compare the voltages your DAQ hardware is reading and writing with what a voltmeter says. If they don't match, something is wrong. I've found that students tend to implicitly believe a hardware reading, even if it's not doing what they think it's doing. Quote
Ton Plomp Posted May 7, 2007 Report Posted May 7, 2007 Alnaimi, I claim your code, show it again. Include a 2D array indicator containing your data. I think my first post solved your problem but currently your having a hardware issue! Ton Quote
alnaimi Posted May 7, 2007 Author Report Posted May 7, 2007 QUOTE(tcplomp @ May 6 2007, 05:07 PM) Alnaimi,I claim your code, show it again. Include a 2D array indicator containing your data. I think my first post solved your problem but currently your having a hardware issue! Ton See the second graph !! it is the latest one !! and the bundle is not working with me so I remove it ! You know what is the problem : ANalog Input is working in the first iteration of loop only ! But in second iteration it did not work I mean VDS =0,1,2,3,4,5 when VGS =3 but in the second time wheh VGS =4 and when it is =5 it dors not work !!! All the hardware is function ok ! Quote
Ton Plomp Posted May 7, 2007 Report Posted May 7, 2007 Alnaimi, last time: Where is you code, please include the data set you have (create an indicator) Ton Quote
alnaimi Posted May 9, 2007 Author Report Posted May 9, 2007 oh yes thanks for your help , you know I have fix my problem by outputing every curve in a SEPARATE " EXPRESS Graph" which has the current as a Y axis and a VDS as X axis ,, So I have 3 extended graphs now I want to merge them in One graph but merging icon is not working coz EXPRESS graph has pink wire while merge need blue one !! can u help plz Quote
Ton Plomp Posted May 9, 2007 Report Posted May 9, 2007 QUOTE(tcplomp @ May 4 2007, 02:31 PM) Ok so what is the problem,please show your code with my solution applied! Ton QUOTE(tcplomp @ May 6 2007, 09:37 AM) Alnaimi, I claim your code, show it again. Include a 2D array indicator containing your data. I think my first post solved your problem but currently your having a hardware issue! Ton QUOTE(tcplomp @ May 6 2007, 09:15 PM) Alnaimi, last time: Where is you code, please include the data set you have (create an indicator) Ton QUOTE(alnaimi @ May 8 2007, 03:57 PM) oh yes thanks for your help , you know I have fix my problem by outputing every curve in a SEPARATE " EXPRESS Graph" which has the current as a Y axis and a VDS as X axis ,, So I have 3 extended graphs now I want to merge them in One graph but merging icon is not working coz EXPRESS graph has pink wire while merge need blue one !! can u help plz Forget Express graphs! Final call, please upload some code Ton Quote
alnaimi Posted May 9, 2007 Author Report Posted May 9, 2007 OK I have edited my post plz find it , I am generating each curve in separet graph then I want 2 merge them ! merging is not working neither bundle! Quote
Dirk J. Posted May 9, 2007 Report Posted May 9, 2007 QUOTE(alnaimi @ May 8 2007, 04:18 PM) OK I have edited my post plz find it , I am generating each curve in separet graph then I want 2 merge them ! merging is not working neither bundle! sigh... again your code is broken. as I told you before, most of us do not have the KIDAQ subVI's. Quote
alnaimi Posted May 9, 2007 Author Report Posted May 9, 2007 YAAAH i KNOW but IA M ASKING ABOUT THE CONCEPT no one Quote
Dirk J. Posted May 9, 2007 Report Posted May 9, 2007 QUOTE(alnaimi @ May 8 2007, 06:11 PM) YAAAH i KNOW but IA M ASKING ABOUT THE CONCEPT no need to shout. the code you uploaded does not clarify what you want. what do you want with the for as far as I can tell, you just duplicated your code into a second frame. if I understand your question, what you want is shown in the ...\National Instruments\LabVIEW 8.2\examples\general\graphs\gengraph.llb\XY Graph.vi example. Quote
