LAVA 1.0 Content Posted May 18, 2007 Report Posted May 18, 2007 QUOTE(Aristos Queue @ Feb 2 2007, 09:44 PM) Basic principle: An app instance should always be treated as a separate machine. If the code works in separate app instances, then it should work on separate machines. Behind the scenes, LV might cheat for two app instances on the same computer, but the same VIs must still work if the app instances aren't co-machine. Hi, I know that thread is starting to be "old", but it let me doubtfull. Is there really a way to pass data between 2 EXEs (built with LV 7.1.1) running on the same computer through VI server ? I ask this because I've been transfering data between 2 EXEs for for a long time, but one EXE was on a Windows PC and the other EXE was running on an RT PXI... so I though it was going to be as easy as the example "VI server Manager application" (example that comes with LV 7.1.1), but apparently it works only betwwen a WinEXE and a RT EXE. Am I wrong ? A small example or a screenshot would be very highly appriciated (a diagram is worth a thousand word ) Quote
jpdrolet Posted May 18, 2007 Report Posted May 18, 2007 Here: APP1 enables its VI Server on its specific port. APP2 connects using Open Application Reference. Quote
Yair Posted May 18, 2007 Report Posted May 18, 2007 To elaborate on JP's answer, I believe the port has to be different from the default one (although I'm not sure). Quote
LAVA 1.0 Content Posted May 18, 2007 Author Report Posted May 18, 2007 QUOTE(jpdrolet @ May 17 2007, 02:28 PM) Here: APP1 enables its VI Server on its specific port. APP2 connects using Open Application Reference. Hi, Does it actually work if you build 2 EXEs and run them on the same PC I've checked my LabVIEW options VI server settings... everything is enabled. First "localhost" will NEVER be accepted, neither in LV code nor in EXE. Then "+IP address" will be accepted but then no VI name will work... :headbang: After a couple of lost hours I can't have a clear overview of such a basic thing... I really feel stupid, I guess there is a wrong setting somewhere else than in the VI... but where ? http://forums.lavag.org/index.php?act=attach&type=post&id=5896 http://forums.lavag.org/index.php?act=attach&type=post&id=5897 Quote
jpdrolet Posted May 18, 2007 Report Posted May 18, 2007 For sure it works, maybe the syntax is wrong. Alternatively, you can include the following lines in the application INI file: server.tcp.port=33363 server.tcp.access="+*" server.tcp.enabled=True server.vi.access="+*" server.tcp.paranoid=False You can also enable the Applcation Item "APP_OPTIONS" in the run-time of the application and edit the VI Server options there. Lines similar to the above will be written in the INI file. The above settings exposes all VIs to all incoming connections so you may want to restrict access only to your intranet or come VIs. I usually set server.vi.access="+Server*" so only VIs with names beginnig with Server are accessible from the VI Server interface. Maybe the "+" is missing in arg3, so sorry my mistake... Quote
LAVA 1.0 Content Posted May 18, 2007 Author Report Posted May 18, 2007 QUOTE(jpdrolet @ May 17 2007, 08:41 PM) server.tcp.paranoid=False I love that one ! QUOTE(jpdrolet @ May 17 2007, 08:41 PM) I usually set server.vi.access="+Server*" so only VIs with names beginnig with Server are accessible from the VI Server interface. Maybe the "+" is missing in arg3, so sorry my mistake... That sounds like a good trick ! Thanks a lot for your help ! :worship: I was about to Quote
Rolf Kalbermatter Posted May 19, 2007 Report Posted May 19, 2007 QUOTE(TiT @ May 17 2007, 12:42 PM) Hi,Does it actually work if you build 2 EXEs and run them on the same PC I've checked my LabVIEW options VI server settings... everything is enabled. First "localhost" will NEVER be accepted, neither in LV code nor in EXE. Then "+IP address" will be accepted but then no VI name will work... :headbang: After a couple of lost hours I can't have a clear overview of such a basic thing... I really feel stupid, I guess there is a wrong setting somewhere else than in the VI... but where ? http://forums.lavag.org/index.php?act=attach&type=post&id=5896 http://forums.lavag.org/index.php?act=attach&type=post&id=5897 If you want to run the two exes on the same computer you should not use the same IP port number. Only one application (and even thread) can open a specific IP port on a machine at the same time, so the second executable that starts up will fail to initialize a VI server instance if it is run on the same machine. Should probably still allow the second app to access the first app as client but otherwise around can't work as the second app has no properly initilialized VI server. Rolf Kalbermatter Quote
