h5labview on cRIO?
Hello
I am using h5labview on a windows PC connected to a cRIO. This seems to work fine. I rather would like the file save be running on the cRIO though. Does anyone know if there is a howto on this subject? The most recent link I can find is this one:
https://sourceforge.net/p/h5labview/discussion/general/thread/479d0cdf61/?limit=25#c81d
the link is a few years old and if I would be able to compile and get a *.o file I would not know howto use it on the cRIO. I have some Linux experience I can setup a VM with Linux. I use Labview 2024.
any help is appreciated thank you!
It's a little more complicated than that. You do not just need an *.o file but in fact an *.o file for every c(pp) source file in that library and then link it into a *.so file (the Linux equivalent of a Windows dll). Also there are two different cRIO families the 906x which runs Linux compiled for an ARM CPU and the 903x, 904x, 905x, 908x which all run Linux compiled for a 64-bit Intel x686 CPU. Your *.so needs to be compiled for the one of these two depending on the cRIO chassis you want to run it on. Then you need to install that *.so file onto the cRIO.
In addition you would have to review all the VIs to make sure that it still applies to the functions as exported by this *.so file. I haven't checked the h5F library but there is always a change that the library has difference for different platforms because of the available features that the platform provides.
The thread you mentioned already showed that alignment was obviously a problem. But if you haven't done any C programming it is not very likely that you get this working in a reasonable time.
  • 2 weeks later...
Hello Rolf,
thank you for the help. I did download the source files from HDF5 and HDF5Labview. You're are right it can take some time to get it working. For that reason I'll start with making a datastream from the cRIO to the windowns gui pc and use that for now. At least I'll be able to reduce some risk.
Meanwhile I'll try to get a the Cross compiler working I'll should at lease be able to get a "hello world" running on the cRIO and take some steps if I can find some time. I did find the following site:
https://nilrt-docs.ni.com/cross_compile/cross_compile_index.html
Do you think this site is still up to date or is it a good point to start?  I am only targeting a Ni-9056 for now.
Thanx!
On 2/24/2026 at 2:31 PM, Neon_Light said:
Hello Rolf,
I haven't recently tried to use that information but will have to soon for a few projects. From a quick cursory glance it would seem still relevant. There is of course the issue of computer technology in general and Linux especially being a continuous moving target, so I would guess there might be slight variations nowadays to what was the latest knowledge when that document was written, but in general it seems still accurate.
Hello Rolf, thank you for the reply. what kind of projects are you starting? (just curious)
2 hours ago, Rolf Kalbermatter said:
Not starting but want to try to do a cRIO variant of a few things such as the OpenG ZIP library, Lua for LabVIEW, and especially my OPC UA Toolkit.
You resurrecting LuaVIEW?
1 hour ago, ShaunR said:
The link is broken for lazy people like me ;)
F*ck! 😁
And I lost my privilege of being allowed to edit posts indefinitely some years ago for unexplained reason.
Ohh well! Not sure I care at this point very much. I just suck at commercial promotional stuff and am admitting it.
Edited by Rolf Kalbermatter
Your fastidiousness with code tells me this is an outright lie. :D
Hey, I didn't talk about code! This was about advertisement and commerce.
(And my lost privilege, which indeed hurts my sensitive soul a little 😁. It's soul crushing to read an old post of myself and discover typos in it.)
It will eat away at you slowly...at first. Then every time you see the link you will know [it doesn't work]. Drip, drip, drip. It's like those crossed wires on your diagram - you tell yourself it doesn't matter, that it's just cosmetic, that there is no change in function. But eventually you have to do something about it. ;) Send that request to the admin, you know you want to :D
I tried hard to ignore your poisonous whisperings but eventually succumbed to it. 🤫
  • Haha 1
Just to wanted add another voice to the LuaVIEW fan club.  LUA is an excellent scripting language and LuaVIEW is an excellent integration with LV.  Keep hoping you might see the advantages of open sourcing it to the LV community.
Thanks for your feedback. I'm not the legal owner of Lua for LabVIEW, only the maintainer. It is unfortunately not my decision how it is distributed/sold.
But even if it was, I don't think I would actually open source it. But I would probably make it free.
