viSci Posted 22 hours ago Report Posted 22 hours ago (edited) I realize this SQLite LIbrary (by ShaunR) is pretty ancient so not surprised there maybe some dll updating required but I thought I would inquire. I have used it many times in the past and have come to appreciate its performant well crafted design. Edited 22 hours ago by viSci Quote
ShaunR Posted 22 hours ago Report Posted 22 hours ago The SQLite API for LabVIEW was retired 6 years ago (at version 5.0.0). Quote
viSci Posted 18 hours ago Author Report Posted 18 hours ago (edited) That is considerably more modern then my v1.3.1, I would give it a go if you could make it available... Edited 18 hours ago by viSci Quote
ShaunR Posted 4 hours ago Report Posted 4 hours ago If you have a commercial waiver then there is limited residual support but apart from that, you should be looking to transition to an alternative product. Quote
hooovahh Posted 7 minutes ago Report Posted 7 minutes ago There are several SQLite libraries on VIPM.io. I personally use the one by JDP Science, but a few others also look promising. Changing over will obviously take some time finding and replacing one API for another, especially if there are differences in design choices in how they each implement similar functionality. Quote
