viSci Posted Sunday at 01:27 PM Report Posted Sunday at 01:27 PM (edited) I realize this SQLite LIbrary (by ShaunR) is pretty ancient so not surprised there maybe some dll updating required but I thought I would inquire. I have used it many times in the past and have come to appreciate its performant well crafted design. Edited Sunday at 01:29 PM by viSci Quote
ShaunR Posted Sunday at 01:55 PM Report Posted Sunday at 01:55 PM The SQLite API for LabVIEW was retired 6 years ago (at version 5.0.0). Quote
viSci Posted Sunday at 05:44 PM Author Report Posted Sunday at 05:44 PM (edited) That is considerably more modern then my v1.3.1, I would give it a go if you could make it available... Edited Sunday at 05:45 PM by viSci Quote
ShaunR Posted yesterday at 07:38 AM Report Posted yesterday at 07:38 AM If you have a commercial waiver then there is limited residual support but apart from that, you should be looking to transition to an alternative product. Quote
hooovahh Posted yesterday at 12:08 PM Report Posted yesterday at 12:08 PM There are several SQLite libraries on VIPM.io. I personally use the one by JDP Science, but a few others also look promising. Changing over will obviously take some time finding and replacing one API for another, especially if there are differences in design choices in how they each implement similar functionality. Quote
viSci Posted yesterday at 12:49 PM Author Report Posted yesterday at 12:49 PM Thanks. I have already started porting to JDP SQLite. I should have done that a long time ago. Quote
ShaunR Posted 5 hours ago Report Posted 5 hours ago 22 hours ago, viSci said: Thanks. I have already started porting to JDP SQLite. I should have done that a long time ago. If you didn't use the encryption then you could use the SQLite binaries from SQLite.org to keep you running while you transition. I can't remember off-hand if it was supported in 1.3.1 but adding AES=NONE to the project conditional symbols enables the use of vanilla SQLite binaries (i.e. comments out encryption function calls). That said, I expect the issue with LV2025 is probably to do with calling parameters rather than the binary itself because V5.0.0. seems to work fine with LV 2025 & 2026. Quote
viSci Posted 3 hours ago Author Report Posted 3 hours ago I did try the latest sqlite dll from SQLite.org and also adding the AES symbol to the project but still crashes. Quote
ShaunR Posted 2 hours ago Report Posted 2 hours ago 1 hour ago, viSci said: I did try the latest sqlite dll from SQLite.org and also adding the AES symbol to the project but still crashes. It is probably one or more misconfigured CLFN's somewhere that was fixed in later versions. It was worth a try though. Quote
viSci Posted 42 minutes ago Author Report Posted 42 minutes ago It crashes running any of the included examples. It seems to be able to open a reference to the .db but any queries crash. Quote
ShaunR Posted 8 minutes ago Report Posted 8 minutes ago 34 minutes ago, viSci said: It crashes running any of the included examples. It seems to be able to open a reference to the .db but any queries crash. Indeed. That is usually the result of misconfigured CLFN's. Quote
