viSci Posted Sunday at 01:27 PM Report Posted Sunday at 01:27 PM (edited) I realize this SQLite LIbrary (by ShaunR) is pretty ancient so not surprised there maybe some dll updating required but I thought I would inquire. I have used it many times in the past and have come to appreciate its performant well crafted design. Edited Sunday at 01:29 PM by viSci Quote
ShaunR Posted Sunday at 01:55 PM Report Posted Sunday at 01:55 PM The SQLite API for LabVIEW was retired 6 years ago (at version 5.0.0). Quote
viSci Posted Sunday at 05:44 PM Author Report Posted Sunday at 05:44 PM (edited) That is considerably more modern then my v1.3.1, I would give it a go if you could make it available... Edited Sunday at 05:45 PM by viSci Quote
ShaunR Posted Monday at 07:38 AM Report Posted Monday at 07:38 AM If you have a commercial waiver then there is limited residual support but apart from that, you should be looking to transition to an alternative product. Quote
hooovahh Posted Monday at 12:08 PM Report Posted Monday at 12:08 PM There are several SQLite libraries on VIPM.io. I personally use the one by JDP Science, but a few others also look promising. Changing over will obviously take some time finding and replacing one API for another, especially if there are differences in design choices in how they each implement similar functionality. Quote
viSci Posted Monday at 12:49 PM Author Report Posted Monday at 12:49 PM Thanks. I have already started porting to JDP SQLite. I should have done that a long time ago. Quote
ShaunR Posted Tuesday at 11:45 AM Report Posted Tuesday at 11:45 AM 22 hours ago, viSci said: Thanks. I have already started porting to JDP SQLite. I should have done that a long time ago. If you didn't use the encryption then you could use the SQLite binaries from SQLite.org to keep you running while you transition. I can't remember off-hand if it was supported in 1.3.1 but adding AES=NONE to the project conditional symbols enables the use of vanilla SQLite binaries (i.e. comments out encryption function calls). That said, I expect the issue with LV2025 is probably to do with calling parameters rather than the binary itself because V5.0.0. seems to work fine with LV 2025 & 2026. Quote
viSci Posted Tuesday at 01:09 PM Author Report Posted Tuesday at 01:09 PM I did try the latest sqlite dll from SQLite.org and also adding the AES symbol to the project but still crashes. Quote
ShaunR Posted Tuesday at 02:50 PM Report Posted Tuesday at 02:50 PM 1 hour ago, viSci said: I did try the latest sqlite dll from SQLite.org and also adding the AES symbol to the project but still crashes. It is probably one or more misconfigured CLFN's somewhere that was fixed in later versions. It was worth a try though. Quote
viSci Posted Tuesday at 04:08 PM Author Report Posted Tuesday at 04:08 PM It crashes running any of the included examples. It seems to be able to open a reference to the .db but any queries crash. Quote
ShaunR Posted Tuesday at 04:42 PM Report Posted Tuesday at 04:42 PM 34 minutes ago, viSci said: It crashes running any of the included examples. It seems to be able to open a reference to the .db but any queries crash. Indeed. That is usually the result of misconfigured CLFN's. Quote
viSci Posted Tuesday at 05:33 PM Author Report Posted Tuesday at 05:33 PM Are you suggesting that the problem was non-uniform application of the pointer-sized integer CLFN parameters? Quote
ShaunR Posted Tuesday at 05:41 PM Report Posted Tuesday at 05:41 PM 4 minutes ago, viSci said: Are you suggesting that the problem was non-uniform application of the pointer-sized integer CLFN parameters? Not necessarily but possibly. Pointer to data instead of value or vice versa, enum sizes, pointer de-references of strings etc. Library calls are trixy. Quote
Rolf Kalbermatter Posted Thursday at 01:13 PM Report Posted Thursday at 01:13 PM (edited) On 6/2/2026 at 7:41 PM, ShaunR said: Not necessarily but possibly. Pointer to data instead of value or vice versa, enum sizes, pointer de-references of strings etc. Library calls are trixy. Just one wild guess that recently bit me in another library. Does the SQLLite API in the Windows DLL use stdcall calling convention? Until LabVIEW 2011, LabVIEW had a "helpful" feature to second guess your choice of that calling convention in the Call Library Node if the exported function had the appendix @xx with xx indicating the number of bytes passed on the stack for the parameters. The calling convention was silently "corrected" to stdcall even if you had cdecl in the configuration. Once you move to LabVIEW 2011 or later, this suddenly crashes as that silent correction was removed without any warning. The correct way when such a feature gets removed would have of course been to mutate the VI when converted from a pre 2011 version to 2011 or later. However the person removing that paternalizing feature did not think about adding an according mutation code path in the InstrumentLoad() function. The thing bit me because I was developing code in LabVIEW 8.6 and had been also testing it in LabVIEW 2020 64-bit to be sure, wrongly assuming I had been accounting for a fairly large range of LabVIEW versions and platforms. Since LabVIEW 64-bit does not have any calling convention to choose from it did not expose that misconfiguration and someone else loading it into a newer LabVIEW 32-bit version found out the hard way that I had messed up. Never mind, I see it is 2025 64-bit LabVIEW so there is no calling convention to get wrong. Edited Thursday at 01:20 PM by Rolf Kalbermatter Quote
ShaunR Posted Thursday at 03:46 PM Report Posted Thursday at 03:46 PM 2 hours ago, Rolf Kalbermatter said: Just one wild guess that recently bit me in another library. Does the SQLLite API in the Windows DLL use stdcall calling convention? Until LabVIEW 2011, LabVIEW had a "helpful" feature to second guess your choice of that calling convention in the Call Library Node if the exported function had the appendix @xx with xx indicating the number of bytes passed on the stack for the parameters. The calling convention was silently "corrected" to stdcall even if you had cdecl in the configuration. Once you move to LabVIEW 2011 or later, this suddenly crashes as that silent correction was removed without any warning. The correct way when such a feature gets removed would have of course been to mutate the VI when converted from a pre 2011 version to 2011 or later. However the person removing that paternalizing feature did not think about adding an according mutation code path in the InstrumentLoad() function. The thing bit me because I was developing code in LabVIEW 8.6 and had been also testing it in LabVIEW 2020 64-bit to be sure, wrongly assuming I had been accounting for a fairly large range of LabVIEW versions and platforms. Since LabVIEW 64-bit does not have any calling convention to choose from it did not expose that misconfiguration and someone else loading it into a newer LabVIEW 32-bit version found out the hard way that I had messed up. Never mind, I see it is 2025 64-bit LabVIEW so there is no calling convention to get wrong. I would probably never have been able to resolve an issue like that. What kind of monster removes anti foot-shooting boots? It's highly likely it was just me misconfiguring some CLFN's. It's obviously been fixed in later versions. I still use the API so would have known if there was an issue with 5.0.0. I think version 1.3 was about 2010 so that version is over 16 years old - an amazing testament to LabVIEW's compatibility really. Quote
Rolf Kalbermatter Posted Thursday at 05:18 PM Report Posted Thursday at 05:18 PM (edited) 1 hour ago, ShaunR said: I would probably never have been able to resolve an issue like that. What kind of monster removes anti foot-shooting boots? It's highly likely it was just me misconfiguring some CLFN's. It's obviously been fixed in later versions. I still use the API so would have known if there was an issue with 5.0.0. I think version 1.3 was about 2010 so that version is over 16 years old - an amazing testament to LabVIEW's compatibility really. There are posts on the NI forum about this, the earliest probably around 2012 or 2013 and I was involved in finding the issue. It's not so difficult when you look at a Call Library Node for a Windows API that crashes and then see that it is configured cdecl as there are virtually no Windows APIs with that calling convention except when they have a variable number of parameters as that can not be done in stdcall where the function itself adjusts the stack just before returning. Why would someone "fix" an anti foot shooting protection? Most likely because there was an important customer wanting to call a DLL that used that naming decoration for whatever strange reason, while it was explicitly compiled to use cdecl, and threatened to sue the poor support person taking their call and sending an assassin squad to the NI head quarter. 😁 And in all honestly it is an ill advised protection that should not be there. What is less nice is that this functionality was simply removed without some mutation code path when upgrading pre 2011 VIs with a Call Library Node to 2011 or later. Yes there are complications, the correction was apparently done at recompilation time by actually verifying the exported name (the Call Library Node doesn't require to enter the decorated name but does the according matching to the real exported function at that moment) so if the VI was loaded in a newer version with the DLL missing, it would be impossible to properly mutate the code, but it would have been at least possible to try to mutate the VI during loading into the new version if the original was older than 2011. As it is that ship has long sailed already and it is a moot point to argue about now. Edited Thursday at 05:22 PM by Rolf Kalbermatter Quote
ShaunR Posted yesterday at 09:14 AM Report Posted yesterday at 09:14 AM (edited) 15 hours ago, Rolf Kalbermatter said: There are posts on the NI forum about this, the earliest probably around 2012 or 2013 and I was involved in finding the issue. It's not so difficult when you look at a Call Library Node for a Windows API that crashes and then see that it is configured cdecl as there are virtually no Windows APIs with that calling convention except when they have a variable number of parameters as that can not be done in stdcall where the function itself adjusts the stack just before returning. Why would someone "fix" an anti foot shooting protection? Most likely because there was an important customer wanting to call a DLL that used that naming decoration for whatever strange reason, while it was explicitly compiled to use cdecl, and threatened to sue the poor support person taking their call and sending an assassin squad to the NI head quarter. 😁 And in all honestly it is an ill advised protection that should not be there. What is less nice is that this functionality was simply removed without some mutation code path when upgrading pre 2011 VIs with a Call Library Node to 2011 or later. Yes there are complications, the correction was apparently done at recompilation time by actually verifying the exported name (the Call Library Node doesn't require to enter the decorated name but does the according matching to the real exported function at that moment) so if the VI was loaded in a newer version with the DLL missing, it would be impossible to properly mutate the code, but it would have been at least possible to try to mutate the VI during loading into the new version if the original was older than 2011. As it is that ship has long sailed already and it is a moot point to argue about now. Ah right. It would be another one of those things I never came across. My API's rarely use functions outside of the binary it is wrapping (exception being ECL which uses some windows functions for things like the certificate store). I tend to use cross platform binaries so windows specific library calls are rare and unlikely to be cdecl. I disagree it is ill advised protection. One of the reasons I chose LabVIEW to start programming in was because it was bullet proof. I think we have had a conversation before that I never encountered crashes in the early days and it would have been because of ant foot-shooting boots like this. Edited yesterday at 09:17 AM by ShaunR Quote
Rolf Kalbermatter Posted 21 hours ago Report Posted 21 hours ago (edited) 3 hours ago, ShaunR said: I disagree it is ill advised protection. One of the reasons I chose LabVIEW to start programming in was because it was bullet proof. I think we have had a conversation before that I never encountered crashes in the early days and it would have been because of ant foot-shooting boots like this. I consider it ill advised since that name decoration is simply a Microsoft convention. Other compilers did in the past not create such names when linking a DLL. So as summary: 1) It's not mandated by Microsoft that a stdcall function should be decorated like that, but simply a convention by their linker. It's also not mandated that a non-stdcall function can't be named that way. 2) So it is not a mechanism to reliably avoid Call Library Node misconfiguration. 3) More importantly, it makes it impossible to call a function that was intentionally named that way but compiled as cdecl. Why would someone create such a function? Well, I have no idea even if you beat me, but obviously someone did, otherwise NI would not have removed that anti-foot-shooter hack. Edited 21 hours ago by Rolf Kalbermatter Quote
ShaunR Posted 1 hour ago Report Posted 1 hour ago 20 hours ago, Rolf Kalbermatter said: I consider it ill advised since that name decoration is simply a Microsoft convention. Other compilers did in the past not create such names when linking a DLL. So as summary: 1) It's not mandated by Microsoft that a stdcall function should be decorated like that, but simply a convention by their linker. It's also not mandated that a non-stdcall function can't be named that way. 2) So it is not a mechanism to reliably avoid Call Library Node misconfiguration. 3) More importantly, it makes it impossible to call a function that was intentionally named that way but compiled as cdecl. Why would someone create such a function? Well, I have no idea even if you beat me, but obviously someone did, otherwise NI would not have removed that anti-foot-shooter hack. The main difference is who cleans up the stack after a function. But again, I have avoided name mangling/decoration because it makes it difficult to figure out what to call. I guess being a mid-wit has saved me again Quote
Rolf Kalbermatter Posted 1 hour ago Report Posted 1 hour ago 1 minute ago, ShaunR said: The main difference is who cleans up the stack after a function. But again, I have avoided name mangling/decoration because it makes it difficult to figure out what to call. I guess being a mid-wit has saved me again Depends what compiler you use. Some are more difficult to force into compliance with your preferences than others.😁 All my DLLs are always cdecl or whatever the preferred calling convention is (Windows 64-bit abandoned with cdecl in favor of fastcall, and trying to force a compiler to do cdecl there, while possible in some compilers, is pretty much doomed for anyone else who is going to have to use that DLL). For Windows APIs however you can't choose, that decision has been made by Microsoft when defining the API. For user DLLs I don't see why anyone ever would have decided to go by stdcall, unless they use a programming environment that could not deal with cdecl. Quote
ShaunR Posted 51 minutes ago Report Posted 51 minutes ago (edited) 19 minutes ago, Rolf Kalbermatter said: Depends what compiler you use. Some are more difficult to force into compliance with your preferences than others.😁 All my DLLs are always cdecl or whatever the preferred calling convention is (Windows 64-bit abandoned with cdecl in favor of fastcall, and trying to force a compiler to do cdecl there, while possible in some compilers, is pretty much doomed for anyone else who is going to have to use that DLL). For Windows APIs however you can't choose, that decision has been made by Microsoft when defining the API. For user DLLs I don't see why anyone ever would have decided to go by stdcall, unless they use a programming environment that could not deal with cdecl. For C/C++ I always use MingW (sometimes in MSYS2, sometimes in Codeblocks) but I prefer Pascal (Free Pascal compiler). Is this something you encounter mainly in MSVC? Edited 50 minutes ago by ShaunR Quote
