george seifert Posted October 3, 2007 Report Posted October 3, 2007 My EXE builder (for at least a couple of projects) has lost information a few times now. Specifically the "Always Inlcuded" section on the Source Files page. Also in the Installer builder unchecked the "Include readme file" setting. I have no idea what triggered this, but I know for sure I didn't mess with those settings (nobody else works with these files). Has anyone else noticed this? George Quote
rkanders Posted October 3, 2007 Report Posted October 3, 2007 Same here. I did have fairly frequent crashes and LV recovered *.proj file. Quote
Justin Goeres Posted October 4, 2007 Report Posted October 4, 2007 QUOTE(rkanders @ Oct 2 2007, 02:45 PM) Same here. I did have fairly frequent crashes and LV recovered *.proj file. Interesting that this gets posted today, because I noticed the same thing for the first time this morning. I, too, have had a few crashes and have probably recovered the .lvproj file a time or two. When I went to build an EXE today (one of several specs in this project), all the Source Files I'd selected before had been removed from the Build Spec. I checked a couple other Build Specs in the project and the same was true of them. I didn't check everything exhaustively. Quote
george seifert Posted October 4, 2007 Author Report Posted October 4, 2007 QUOTE(Justin Goeres @ Oct 2 2007, 09:11 PM) Interesting that this gets posted today, because I noticed the same thing for the first time this morning. I, too, have had a few crashes and have probably recovered the .lvproj file a time or two. When I went to build an EXE today (one of several specs in this project), all the Source Files I'd selected before had been removed from the Build Spec. I checked a couple other Build Specs in the project and the same was true of them. I didn't check everything exhaustively. I've had crashes too (which LV8.5 seems to do much more frequently than 8.2) involving the projects that went bad. I suspect the loss of info is related to the recovery process, but I'll have to monitor the situation. George Quote
rkanders Posted October 4, 2007 Report Posted October 4, 2007 I have pretty much stopped using automatic recovery feature. I just do more frequent saves and commits to my SVN repository. Quote
george seifert Posted October 4, 2007 Author Report Posted October 4, 2007 QUOTE(rkanders @ Oct 3 2007, 10:32 AM) I have pretty much stopped using automatic recovery feature. I just do more frequent saves and commits to my SVN repository. Yeah, I'm going to have to think twice about recovering a project again. I looked pretty stupid the other day after I insalled a built project that had been recovered. I knew it used to include all the files it needed, but now they're not there. George Quote
Jim Kring Posted October 4, 2007 Report Posted October 4, 2007 QUOTE(rkanders @ Oct 3 2007, 08:32 AM) I have pretty much stopped using automatic recovery feature. I just do more frequent saves and commits to my SVN repository. I've started doing the same. Quote
JDave Posted October 4, 2007 Report Posted October 4, 2007 QUOTE(Jim Kring @ Oct 3 2007, 01:00 PM) I've started doing the same. If only the Undo stack didn't get flushed every time you save... Is memory really that tight? Buy another few Gigs of RAM. Quote
Jeff B Posted October 4, 2007 Report Posted October 4, 2007 Hey guys, Do you think the project missing items that were there is a problem with autosave, or just the fact that you'd made changes to the project since the last time the autosave occurred? If the former, I'd like to figure out why certain types of information in your projects appears to not be getting autosaved. If you have any further information about whether or not you're able to reproduce this, please let me know. Thanks! Quote
Jim Kring Posted October 5, 2007 Report Posted October 5, 2007 QUOTE(george seifert @ Oct 3 2007, 08:40 AM) Yeah, I'm going to have to think twice about recovering a project again. I looked pretty stupid the other day after I insalled a built project that had been recovered. I knew it used to include all the files it needed, but now they're not there. QUOTE(Jim Kring @ Oct 3 2007, 01:00 PM) I've started doing the same. Another thing that I've started doing (for large projects) is using the Window Task Manager to kill LabVIEW, when I want to close my project, especially if it is showing unsaved changes. Sometimes it can take minutes before LabVIEW shows the "Save Changes?" dialog. Quote
george seifert Posted October 5, 2007 Author Report Posted October 5, 2007 QUOTE(Jeff B @ Oct 3 2007, 03:47 PM) Hey guys,Do you think the project missing items that were there is a problem with autosave, or just the fact that you'd made changes to the project since the last time the autosave occurred? If the former, I'd like to figure out why certain types of information in your projects appears to not be getting autosaved. If you have any further information about whether or not you're able to reproduce this, please let me know. Thanks! I hadn't made any changes to the the part of the project that got wiped out. I was just changing VIs and not anything at all in the installer builder. George Quote
Jeff B Posted October 27, 2007 Report Posted October 27, 2007 Sorry for the delay in response. I've reproduced this. This has been reported to R&D (4ENAG200) for further investigation. Quote
george seifert Posted October 30, 2007 Author Report Posted October 30, 2007 QUOTE(Jeff B @ Oct 26 2007, 01:53 PM) Sorry for the delay in response. I've reproduced this. This has been reported to R&D (4ENAG200) for further investigation. Thanks for checking into it :thumbup: . It'd be nice to be able to rely on Recover to not mess up my project. George Quote
Helmer Posted November 13, 2007 Report Posted November 13, 2007 seems to happen whenever Labview crashes and you get the recovery screen when you start Lv again Quote
Aristos Queue Posted November 13, 2007 Report Posted November 13, 2007 QUOTE(Helmer @ Nov 12 2007, 12:28 PM) seems to happen whenever Labview crashes and you get the recovery screen when you start Lv again It seems like the real solution is to stop LV from crashing. I hope someone is reporting the circumstances for all these crashes so the root can be fixed. Quote
Jeff B Posted April 17, 2008 Report Posted April 17, 2008 This issue (the one with projects losing build spec info after autosave recovery) is fixed in 8.5.1. Of course Aristos Queue is right, we'd prefer to figure out what's causing your crashes in the first place and get those fixed as well, so please report them, particularly if you can reproduce the situation. Quote
