What's wrong with this picture?
QUOTE(Justin Goeres @ Oct 26 2007, 08:34 AM)
What I'm really still dying to know is how the Required Outputs happened. Michael is being awfully coy about that.
This keeps bugging me too. Michael mentioned TS 4.0 in the "broken wire/runnable message", so I'm guessing it has something to do with TS providing access to VI properties that don't normally make sense from a LV standpoint. If it did come from TS, that might explain why Aristos couldn't find a LV way to do this.
I don't have TS, so it's just a guess...
  • 3 weeks later...
QUOTE(Michael_Aivaliotis @ Nov 15 2007, 09:49 AM)
I guess that makes 2 in the special "required outputs" club.
But I'm afraid you are still alone in the "detachable node" club :( .
I was going to explain how I did it, but I don't want to take away your well-earned NIweek beers ;) .
Saludos,
Aitor
  • 3 weeks later...
QUOTE(Tomi Maila @ Nov 30 2007, 07:25 AM)
What's wrong with this video?
It looks like to me like you're somehow changing the execution state of the VI while it's running. You manage to "break" (broken arrow) the VI without stopping it, and it's after that that the weirdness really begins. You sort of "fix" the problem by clicking the Run arrow again, which I suppose gets the VI back to a more self-consistent state and allows the Stop button to work.
I also note that right after you click the Run arrow for the first time, your cursor moves out of the movie frame. :shifty:
Care to make another movie where either
  • your cursor stays in frame the whole time? OR
  • the whole screen is visible?
:P
QUOTE(Aitor Solar @ Nov 15 2007, 02:24 AM)
Well, well, well, it seems really easy when you know how :yes:
Send me a private post or something. If you've got a way to do it, I want to know so I can see how the code is doing it SO I CAN BLOODY WELL MAKE IT A SUPPORTED FEATURE.
QUOTE(Aitor Solar @ Dec 3 2007, 10:11 AM)
I think you are triying to do this, don't you? This avoids the "VI is not in a state compatible with this operation" error.
I'm unable to find this Fake Exec State scripting property. Where can I find it? I was using your and my own scripting tool...
EDIT: I found it, it was a method...
Tomi
  • 1 month later...
Back to original question: Does changing it by means of a hex editor count? 'Cause that's how I did it. Odd side-effect is that the Info window shows the correct display in terms of its wiring property, but when you right-click on the indicator it doesn't.
QUOTE(Saverio @ Jan 4 2008, 05:23 PM)
Did you changed the code of a .vi file? And doesn't LabVIEW return something as "corrupt VI" or similar? :o
Saludos,
Aitor
QUOTE(Aitor Solar @ Jan 7 2008, 03:11 PM)
Saludos,
Aitor
No. I just changed one hex value at a specific location in the file. That changed the behavior of the output to "required". It did not corrupt the VI, as far as I could tell. There was the side-effect that I mentioned, but I don't know if that's because LabVIEW inherently doesn't deal with required outputs, or what.
  • 1 month later...
QUOTE(Michael_Aivaliotis @ Oct 5 2007, 10:57 PM)
Create an XNode, use the Terms ability to create connector pane inputs, set them to required. Place the XNode to a block diagram and open the Generated Code.vi. Make a new VI and drag the Connector Pane of the Generated Code.vi to the new VI. Create the controls and connect them to tha connector pane. Save the VI and voila you have required inputs.
cosmin
QUOTE(Aristos Queue @ Dec 1 2007, 01:04 AM)
DON'T BELIEVE HIM!!!!!!!!!!!
HE JUST WANTS TO BLOCK IT!
I know those evil NI types. :ninja:
cosmin, you wrote "inputs". Does this also apply to outputs?
