Jim Kring Posted October 20, 2007 Report Posted October 20, 2007 When a LabVIEW file (VI, CTL, LVProj, LVClass, etc) links to a file that is located beneath a Symbolic Path, LabVIEW stores the link as a path relative to the symbolic path. However, there are several folders beneath LabVIEW, which should definitely be, but are not, symbolic paths. For example: ./resource/ ./examples/ ./help/ ./project/ I would like to make the following request of NI... Please make <labview> (or <application>) a symbolic path. Any file located beneath the LabVIEW installation root, which is not in a more specific (deeper) symbolic path, should be linked to, relative to the LabVIEW installation root. :2cents: -Jim [update: This has been sent to NI, via the Product Suggestion Center] Quote
Yair Posted October 21, 2007 Report Posted October 21, 2007 Agreed, that would definitely be nice. It might also be nice to have user defined logical folders, but I can see how that can be a problem when moving between computers. Quote
Ton Plomp Posted October 22, 2007 Report Posted October 22, 2007 QUOTE(Yen @ Oct 20 2007, 07:10 PM) Agreed, that would definitely be nice. It might also be nice to have user defined logical folders, but I can see how that can be a problem when moving between computers. Well there are 2, the LabVIEW data folder which by default links to 'My Documents\LabVIEW Data' And the Temp directory which by default links to the OS Temp folder: And there's the default folder which points by default points to the LabVIEW folder (but it can be changed): The problem is that these paths are not symbolic Ton Quote
Aristos Queue Posted October 22, 2007 Report Posted October 22, 2007 I won't get involved with the discussion about more symbolic paths to LV built-in stuff. Technical pros, technical cons, politics, blah, blah, blah... But as far as user-defined paths are concerned, there's a number of technical blocks to with having arbitrary definitions for symbolic paths as they're used on the internals of LV. But I could see someone creating a set of VIs that managed a path translation scheme for loading VIs dynamically from user-defined symbolic paths. Might be useful for one of you to put together. Quote
Yair Posted October 22, 2007 Report Posted October 22, 2007 QUOTE(Aristos Queue @ Oct 21 2007, 03:31 PM) But I could see someone creating a set of VIs that managed a path translation scheme for loading VIs dynamically from user-defined symbolic paths. Might be useful for one of you to put together. I believe OpenG already has quite a few VIs which deal with relative paths, even if not with symbolic paths. I'm sure extending them would not be impossible. The problem here is that statically linked VIs are much easier to work with than dynamic ones, and for that you need the internal LV linker. Quote
Rolf Kalbermatter Posted November 21, 2007 Report Posted November 21, 2007 QUOTE(Yen @ Oct 21 2007, 04:01 PM) I believe OpenG already has quite a few VIs which deal with relative paths, even if not with symbolic paths. I'm sure extending them would not be impossible. The problem here is that statically linked VIs are much easier to work with than dynamic ones, and for that you need the internal LV linker. Actually the OpenG Builder and also the OpenG Commander (and quite likely VIPM as it uses for quite some part still the same VI libraries) does have VIs supporting symbolic paths. I created them back in the early days of OpenG Builder together with the lvzip library to support a flexible package installation system, that the ogp files are still mostly based upon. For the Commander they reside in OGPM PATH Convert Keyword.vi, OGPM PATH Keyword Expand.vi and OGPM Keyword Manager.vi.QUOTE(Aristos Queue @ Oct 21 2007, 08:31 AM) I won't get involved with the discussion about more symbolic paths to LV built-in stuff. Technical pros, technical cons, politics, blah, blah, blah...But as far as user-defined paths are concerned, there's a number of technical blocks to with having arbitrary definitions for symbolic paths as they're used on the internals of LV. But I could see someone creating a set of VIs that managed a path translation scheme for loading VIs dynamically from user-defined symbolic paths. Might be useful for one of you to put together. Only problem with that is that it would not pertain to the paths stored in VIs itself and to loading them as that requires access to LabVIEW interna that can not be dealt with with "App:Read/Write Linker Info from File" afaik. Rolf Kalbermatter Quote
