Help me
LuLu
HI :D
Help me plz :worship:
How can I solve this problem???
You are given the following Reverse Osmosis (RO) plant's basic block diagram by
your Technical Manager and are required to come up with a control scheme in
LabVIEW that follows the following structure:
Inputs:
Source Reservoir Level (L1)
Output Reservoir Level (L2)
Pressure at the input of High Pressure pump (P1)
Pressure at the output of High Pressure pump (P2)
Conductivity of the output water sample ©
Outputs:
Control signal to Low Pressure Pump (C1)
Control signal to High Pressure Pump (C2)
Indicator light for Low Pressure Pump being ON (A1)
Indicator light for High Pressure Pump being ON (A2)
Indicator light for Warning State 1 (A3)
Indicator light for Warning State 2 (A4)
Tank levels for both tanks (TL1, TL2)
Strategy:
For any level indicator, Li = 0 means the tank is empty, Li = 1 means the tank is full.
Any intermediate value would give the level in that tank. For pumps, 1 means the
pump is ON and 0 means the pump is OFF. For conductivity, 0 means no conductivity
and represents pure water. C up to 0.1 is acceptable level of conductivity and any
value higher than that means the membrane is not working correctly and needs
maintenance.
1. As the system is turned on, check L1 to be 1 and L2 to be 0. If so, then turn on
the low pressure pump. If not then indicate the state through A3 and A4.
2. Once the low pressure pump is ON, wait for 30 seconds and check P1. If P1 is
>= 3 bars then turn ON the high pressure pump. Otherwise turn the low
pressure pump OFF and indicate appropriately using A3 and A4.
3. If the high pressure pump is ON then wait for 30 sec and start monitoring C.
At any instant, if C > 0.1 then stop both pumps and indicate appropriately
using A3 and A4.
4. While running, at any instance, if the conditions in 1 or 2 also become true
(i.e. L1 = 0, or L1 = 1, or P1 < 3 bars) then stop both pumps and indicate
accordingly.
A1 and A2 are two LEDs connected directly to C1 and C2 respectively indicating the
state of each pump. TL1 and TL2 are two level indicators between 0 and 1, connected
to the tank levels L1 and L2 respectively, and indicate their respective levels. The
warning LEDs have the following meanings:
A3 A4 Meaning
OFF OFF Normal Operation
OFF ON Level Error (strategy step 1)
ON OFF Pressure Error (strategy step 2)
ON ON Conductivity error (strategy step 3)
A3 and A4 should appear as Green in OFF state and Red in ON state. Use a third
LED for power indicator. Use appropriate switches and numeric control inputs for
providing the input values of L1, L2, P1, P2, and C
Oh and while you are doing LuLu's homework
Could you help me to build a system that monitors every train that passes by on a track (weight, speed, type, number of people carried, temperature, pH, Mood of the driver, coffee spill on the floor, number of non-paying commuters, number of loud-noise MP3 devices, and everyone's credit card details)
LuLu if you don't want to do the homework, quite school
Actually, that's a decent design problem. Kudos to your teacher for giving you a relatively practical assignment.
As tcplomp pointed out, we're not going to do your homework for you. However, if you have specific questions about code you've written (why it's slow, what an error message means, etc.) you'll find people here who are happy to help. And when you have a question, posting sample code along with it so we can see what you're doing is invaluable.
Welcome to the board, and good luck with your assignment.
  • 6 months later...
