Hi
Can you help me in this problem.Actually i tried to connect two VI through two different PC using TCP and cross wires. the connection is perfect .by the way i used the programs that displayed in the NI example Finder categories.these programs are
-passive.vi
-Active.vi
-Client.vi
-server.vi
-sender.vi
-receiver.vi
-when i pinged two computers the connection was perfect,but it shows me an error on icons such as listener.vi ,write.vi and so on..
please help me.
QUOTE(M.M.K @ Dec 12 2007, 10:41 AM)
  Quote
What code do you use on server and client side? Please include a screenshot.
What errors do you receive?
Ton
Thank you anyway.
about the examples that i used , you can find them in on the program of labveiw 8.2 >>>>>>>>>Examples>>>>>>>>>find examples>>>>>>networking>>>>>>>>>TCP&UDP Then you can find all the programes there
DO NOT click on the links to the screenshots; they point at a website in a foreign language, and not at full-size images. Reported to the moderator.
QUOTE(ned @ Dec 12 2007, 09:17 AM)
  Quote
if you click on the text part of the link wher eit says Reduced: blah blah blah you get the screenshots , if you click on the image of the screen shot yes you go to a foreign language site....
Dan
This most likely means that a firewall is blocking one or both of your LabVIEW instances. Make sure the LabVIEW application has permission to send TCP traffic.
QUOTE(Yen @ Dec 12 2007, 05:03 PM)
  Quote
the firewall is off for both computers.How can the labview application have permission to send TCP traffic.Can you give me the steps ?
QUOTE(M.M.K @ Dec 13 2007, 01:42 AM)
  Quote
Does it work with both applications locally?
Are you sure you use the correct IP adres?
If the first answers no, you have messed with the VIs somehow rendering them unoperable. I know the examples you mention work fine for me.
If you know your IP adress is right too, this is definitely out of LabVIEWs control, and something in your system, network setup or whatever is blocking you. In that case there is not much we could do for you as we can't see the system and check its settings.
Rolf Kalbermatter
QUOTE(rolfk @ Dec 13 2007, 08:23 AM)
  Quote
Rolf Kalbermatter
i ping two computers with correct IP addreses and shows me that the connection is worked but the errors comes from the program specifically from the listener.vi and the write.vi actually we connecte them through a cross cable.Can you tell me about your connection how you connect them specifically,Please?
QUOTE(M.M.K @ Dec 13 2007, 05:49 AM)
  Quote
Simple office network with DHCP. Obviously with a cross cable DHCP won't work but that you must have found out otherwise ping couldn't work either.
Rolf Kalbermatter
QUOTE(M.M.K @ Dec 13 2007, 11:49 AM)
  Quote
Do you have the same port set for writer and listener?
Ton
  • 2 weeks later...
