Sign in to follow this
Justin Goeres
8.6 Block Diagram Cleanup Comparisons
QUOTE (Michael_Aivaliotis @ Nov 20 2008, 10:45 PM)
A fast solution for NI could be: The choice between "CleanUp All" and "CleanUp Selection". Selecting the 2 problems cases and clicking Cleanup will produce a better result with existing clean up algorythm. Often only a part of the diagram needs cleanup.
Share this post
Link to post
Share on other sites
QUOTE (Michael_Aivaliotis @ Nov 20 2008, 09:45 PM)
It likes vertical alignment a little to much, the VIs are aligned with the for loop and the enum and unbundle are aligned with the bundle function.
QUOTE (Donald @ Nov 21 2008, 12:50 PM)
Ditto that.
Another point, don't quote full messages (esp. with images).
Ton
Share this post
Link to post
QUOTE (Aristos Queue @ Sep 12 2008, 10:31 AM)
Regarding the CAR that the wire routed under the string constant... I got an update from one of the developers who works on Diag. Clean Up:
This is the expected behavior, with the default settings for auto Horizontal-Compactness. If the user moves the setting for Horizontal compactness to lowest, then the Diagram Clean Up will ensure that the wires will not go under the blocks.
Quoting from the Tools>>Options dialog documentation:
"Horizontal compactness—Determines how compact to make the block diagram. Higher compactness causes LabVIEW to take longer to clean up the block diagram and can cause LabVIEW to reroute wires under objects. This control is grayed out unless you select Manual tuning. LabVIEW considers labels as part of a block diagram object. "
Even though this is a known issue, I am keeping this bug open because I could see that wire-routing in general is pretty bad in the given VI. The excessive bends in wires appear to be related to another known issue caused by shift registers, which we are currently working on.
I guess what is needed is the concept of anchoring labels. If we could anchor a label to string or a free floating label to a section of code then the cleanup tool could do a better job of keeping things together in the first place.
Share this post
Link to post
Does anyone know the mathematical backgrounds of this tool? It must be a topological optimization problem like travelling-salesman-problem.
It's interesting to know if there is a "best solution" or if such an algorithm only finds local minima.
I'd like to know how one can optimize between
  • minimize of total wirelength
  • minimize number of crossings
  • minimize number of wire edges
another point: this tool should simultaneously work during creation of a block diagramm and automatically snap the objects to optimum positions like a dynamically intelligent grid
Share this post
Link to post
QUOTE (horatius @ Dec 4 2008, 06:48 PM)
It occurs to me that this might make a good advanced track NI Week presentation. I'll mention it to folks and see if it gets any traction.
Share this post
Link to post
QUOTE (Aristos Queue @ Dec 4 2008, 05:06 PM)
FWIW I'd definitely be interested in it.
Share this post
Link to post
QUOTE (horatius @ Dec 5 2008, 12:48 AM)
Ugghh, no ! Please no !
Surely I can't be the only one who drops things in places which I think will be near where they need to be when I've finished the diagram. The thought that LabVIEW might decide to out guess me and move things around before I'd finished makes even some of Word's 'intelligent' features look good. Unless of course LabVIEW code automatically write the rest of the vi based on my half-formed mental plan of the vi... ;)
Share this post
Link to post
QUOTE (Gavin Burnell @ Dec 5 2008, 02:21 PM)
I agree. The last thing I need is to have my dev environment try to outwit me... :wacko:
Share this post
Link to post
QUOTE (orko @ Dec 5 2008, 05:57 PM)
We sure don't want to have monkeys do our job, don't we? Could they?
Share this post
Link to post
The snap to grid option already exists. I'm not sure if it works in the BD as well, but you can check that in the options menu.
P.S. I agree this might make an interesting NIWeek session.
Share this post
Link to post
QUOTE (Michael_Aivaliotis @ Dec 7 2008, 04:15 AM)
Shift-registers adds extra constraints to the layout algorithm. Perhaps this may be leading to wires bending all around.
But, again, this could just be one of the many possible reasons ( including glitches in the algorithm.)
Two things worth checking are :
1. Try with Manual Tuning with LayoutQuality set to max and keep the horizontal compactness to 2nd or 3rd position.
2. (Just for confirmation,) remove the shift register (or replace with tunnel) and see if that's any better.
-Regards,
Anand
Share this post
Link to post
QUOTE (anandk @ Dec 8 2008, 04:23 AM)
Settings
post-2-1229133734.png?width=400
Result:
post-2-1229133755.png?width=400
Same settings and Shift registers changed to tunnels:
post-2-1229134012.png?width=400
It's better but I still see a lot of unnecessary bends in the wires. I think priority must be placed on keeping wires straight above other factors.
I was working on another VI cleanup and something bad happened. There were several for loops that suddenly became overlapped with other structures. Also some structures resized beneath other objects.
Settings:
post-2-1229134706.png?width=400
Result:
post-2-1229134742.png?width=400
When I switched automatic mode off (into manual) it didn't do this. Thank god for undo!
Share this post
Link to post
When does this NIWeekSession take place? What is this? How to attend?
I think the basic principles of arranging points under restrictions and connect them is already solved and discussed in mathematical journals. NI just has to applay this knowledge. Is anyone a scientist in this field and can give some literature as I don't think that NI (as a monopole) will make it public?
Share this post
Link to post
