Need help to create a steering wheel control
I am trying to create a steering wheel from a knob but I still not have any luck. I did make the value from 0 to 360 and the value is spreaded around the circle already. But I have problem with the moving part of the control. The only moving part is the needle but looks like I cannot replace it. Do you have any suggestion for this one? This part is really important with the GUI of my project.
I highly appreciate your helps.
Hi Thang,
I have a simple 2D image rotation that you might use (with some tweaks to have a better GUI). I've set it up with a steering wheel jpeg for you to try. If that's close to what you need, you'll have to improve it by trimming the edges and perhaps smoothing the image by doing some interpolating. Anyhow, try this out...
Saved for 8.0. (OpenG Arrays library needed)
Download File:post-10515-1226381134.zip
