professor_rumsdiegeige Posted January 22, 2009 Report Posted January 22, 2009 Hello! I read measurement values out of a file. For each measurement, I also read the year, the month and the day of the measurement. This file is not created by Labview. Now I would like to convert these three numbers I have (year, month and day as integers) to a TimeStamp. How is this possible? Quote
hooovahh Posted January 22, 2009 Report Posted January 22, 2009 Use the Date/Time to Seconds primitive VI found in the Timing sub-palette. With this you give a cluster of inputs (including but not limited to Day of Month, Month, and Year) and the output is a Time Stamp. Quote
Antoine Chalons Posted January 22, 2009 Report Posted January 22, 2009 QUOTE (professor_rumsdiegeige @ Jan 21 2009, 06:33 PM) Hello!I read measurement values out of a file. For each measurement, I also read the year, the month and the day of the measurement. This file is not created by Labview. Now I would like to convert these three numbers I have (year, month and day as integers) to a TimeStamp. How is this possible? Maybe this can help : http://lavag.org/old_files/monthly_01_2009/post-7452-1232564875.png' target="_blank"> Quote
professor_rumsdiegeige Posted January 24, 2009 Author Report Posted January 24, 2009 QUOTE (hooovahh @ Jan 21 2009, 07:19 PM) Use the Date/Time to Seconds primitive VI found in the Timing sub-palette. With this you give a cluster of inputs (including but not limited to Day of Month, Month, and Year) and the output is a Time Stamp. Thanks, this solved my problem! Quote
