Insert Phi
ASTDan
QUOTE (ASTDan @ Feb 23 2009, 11:35 AM)
I confirmed that this doesn't work in XP with LV8.2 (that's all I had installed). What happens if you open this vi? It should look about like the screenshot I posted above, but with each character in its own comment/constant.
Edited to remove attachment
QUOTE (TobyD @ Feb 23 2009, 11:52 AM)
I pulled the attachment because it appears to have done some weird things...when I closed it, it crashed LV with this error:
post-8758-1235419361.jpg?width=400
When I relaunched LabVIEW, the other VI that I had opened looks like it has been converted to Japanese (the block diagram too)!!!
post-8758-1235419314.png?width=400
I don't have time to try to reproduce the issue now, but it looks like there might be a bug here somewhere. If you want to play with it AT YOUR OWN RISK here is the VI.
Download File:post-8758-1235419516.vi
QUOTE (TobyD @ Feb 23 2009, 03:06 PM)
It's work for me in XP with LV8.6.1
I also notice that if I change to Hex display, the hex is C603. But... if I entered C603 in Hex display mode I got (text removed) when I come back to Normal display.
QUOTE
I opened the VI and I see the Phi Symbol
Why does that work?
Dan
QUOTE (ASTDan @ Feb 23 2009, 05:06 PM)
Why does that work?
Dan
It did on my system, but if you change the font size and add a roman letter to the same text strip (say phi + f), you'll mess it up (XP, 8.6) and get something similar to pdc's odd characters.
If you don't need to change it programmatically, I would suggest you use a picture of Phi instead of string... I've fought with them in LV7 and gave up.
That would work but I need to add some more text after that. It seems a cell can't contain multiple fonts i.e. symbol and arial.
This is what I want it to display
(text removed) Short
Dan
QUOTE
Could you create a picture control, display the text you want and superimpose on your column header? That looks more and more like Bob's suggestion to Chris!
I have also Posted on NI discussion forum
http://forums.ni.com/ni/board/message?boar...=389325#M389325
I still can't insert phi into LabVIEW so I have to download the posted VI, and copy and paste phi into a free label into my LabVIEW. I can then super impose the free label in the column header.
Ugly but it works
post-8614-1235489018.jpg?width=400
