CzaroK Posted February 25, 2009 Report Posted February 25, 2009 Hi. I'm working with the DB Connectivity Tools. I want to do exe-file from my VI, and I've got problem. I need add database file (MS Access file) to ODBC system source in LabView, and if it's possible create datalink in LV (without using Tools->Create Datalink). Somebody advices me to use the odbccp32.dll and the SQLConfigDataSource function, but it doesn't work. I put my VI in the attachment. Maybe somebody helps me ? Quote
jcarmody Posted February 25, 2009 Report Posted February 25, 2009 Is there anything preventing you from using a connection string instead of a datalink? Quote
Val Brown Posted February 25, 2009 Report Posted February 25, 2009 There are a number of examples available via the web for interconnecting to an Access mdb file using the DCT. I'm not where I have that list at this time but I would think a search on the NI forums or support link would work using keywords like "Access", "Database Connectivity", etc. Quote
MikaelH Posted February 25, 2009 Report Posted February 25, 2009 I normally use a udl-file. (create a empty text file and rename it to something.udl , and then double click on it) My software reads this UDL/Text file and grabs the Provider string from it. E.g. Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=Production;Data Source=MYSERVER The file is unicode and so you have to strip off all NULL-characters. If the file don't exists I start by creating it by just writing this Unicode-text file. Cheers, Mikael Quote
crelf Posted February 25, 2009 Report Posted February 25, 2009 QUOTE (MikaelH @ Feb 24 2009, 04:37 PM) I normally use a udl-file. Here are some very basic UDL file VIs that might be useful (yes, I know that at least one dependancy is missing - get over it! ) Quote
Rolf Kalbermatter Posted March 9, 2009 Report Posted March 9, 2009 QUOTE (CzaroK @ Feb 24 2009, 11:10 AM) Hi.I'm working with the DB Connectivity Tools. I want to do exe-file from my VI, and I've got problem. I need add database file (MS Access file) to ODBC system source in LabView, and if it's possible create datalink in LV (without using Tools->Create Datalink). Somebody advices me to use the odbccp32.dll and the SQLConfigDataSource function, but it doesn't work. I put my VI in the attachment. Maybe somebody helps me ? There are a few caveats with this for sure. First you can not add a System ODBC Data Source if you do not have administrator or at least power user rights. So I doubt this is what you want to do in a built executable. Also you can simply format the parameters that would otherwise be created with the ODBC Data Source Manager dialog into a string and pass that string to the Open Database function as connection string, instead of a name to an ODBC data source. To see what you would need to put in a string you can basically configure on your development machine such a datasource through the ODBC manager and then fgo into the registry and look at the keys in the section for your data source in HKEY_CURRENT_USER\Software\ODBC\ODBC.INI for user data sources and HKEY_LOCAL_MACHINE\Software\ODBC\ODBC.INI for system data sources. You basically just put each value in there in a format <keyname>=<keyvalue> and separate each such expression with a semicolon and you should be fine. No need to create a Data Source and you can even format the actual path to your .mdb file no matter where you have it installed. Rolf Kalbermatter Quote
