[LVTN] Code Capture Tool
index.php?app=downloads&module=display&section=screenshot&id=63
Name: Code Capture Tool
Submitter: Ton Plomp
Submitted: 03 Jul 2009
Category: LabVIEW Tools Network Certified
LabVIEW Version: 2009
License Type: BSD (Most common)
The Code Capture tool allows you easily create screenshots of you LabVIEW code for use in documentation, web-sites, wikis, emails.
This tool provides an API for creating images of LabVIEW code as well a GUI for easy capturing and use of code.
Further info is provided in the help-screen (F1) of the program.
For the latest version visit the Code Repository
For the latest version of the source code, visit SourceForge
For more info, visit the LabVIEW wiki with the documenation.
A series of videos is available on screencast: Code Capture Tool
Installation
To install the Code Capture Tool, run the 'Install Code Capture Tool.vi' in the LabVIEW version of your choice, or use the OGP file in conjunction with VIPM.
A wizard will guide you through the installation procedure.
Usage
After installing and restarting LabVIEW, you can open the Code Capture Tool via the 'Tools' menu to capture an image of the current VI.
For more info open the About screen of the GUI.
Uninstalling
To remove the Code Capture Tool from your LabVIEW installation remove the following files in your LabVIEW folder:
Project\Code Capture Tool.vi
user.lib\CCT.mnu
And the following folder:
user.lib\_Code Capture Tool
In your LabVIEW data folder (in Windows, this is normally: My documents\LabVIEW Data) is a configuration file called Code Capture Tool.ini, which can be removed at any moment. However this file can be shared between mulitple versions of LabVIEW, I recommand you to use a special LabVIEW data folder for each LabVIEW version.
Contact
Comments, bugs and thank yous can be expressed to the NI Forums community , and on the LAVA community at the CCT discussion thread.
  • Like 2
  • 3 months later...
Hi All,
I am looking for beta testers of a new version of the Code Capture Tool.
Especially people in posession of multiple LabVIEW versions on Mac and Linux.
So if you could sent me a PM with your configuration, I try to respond to you.
Ton
  • 1 month later...
I tried to install this from VIPM without success.  VIPM couldn't install it for LV 8.2; 8.6 completed successfully but I got an "Error 7 occurred at Open Config Data.vi" in 8.6.  I went back and ran Install Code Capture Tool.vi in 8.6 and got the same error.
Without CCT, I'll have to resort to  taking pictures of my monitor to attach to my posts.   :wacko:
  On 11/27/2009 at 2:00 PM, Ton Plomp said:
what OS are you on?
Do you have read/write privileges on your LabVIEW data folder? Especially the Code Capture Tool.ini file?
Windows XP
Yes
Could you run the Install Code Capture Tool.vi on 8.2?
I have tested the OGP file on Vista for all versions I currently have (7.0-2009)
  On 11/27/2009 at 7:24 PM, jcarmody said:
Windows XP
Yes
Will try to check that later.
I will sent you an edited version privatly.
Ton
I just tried Install Code Capture Tool.vi on 8.2 without success.  I've attached a screen capture of the result.  A small window flashes after a slight pause, before the error message comes up.  Perhaps that's a clue to what's happening?
I tried the version you sent privately, but it didn't change anything.  Perhaps I'll wait a few days to see if other folks with XP have the same trouble I'm having.  I'd hate to have you spend time fixing something that isn't broken on your end.
Thanks.
cct.swfFetching info...
Thanks.
I was able to replicate the problem you have (on XP)
Trying to debug...
Ton
Here's a demonstration video with the new (2.0) features:<br/>
<object width="360" height="554"> <param name="movie" value="http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/CCT2.0_controller.swf"></param>'>http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/CCT2.0_controller.swf"></param> <param name="quality" value="high"></param> <param name="bgcolor" value="#FFFFFF"></param> <param name="flashVars" value="thumb=http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/FirstFrame.png&containerwidth=360&containerheight=554&showstartscreen=true&showendscreen=true&loop=false&autostart=false&color=1A1A1A,1A1A1A&thumb=FirstFrame.png&thumbscale=45&content=http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/CCT2.0.mp4"></param> <param name="allowFullScreen" value="true"></param> <param name="scale" value="showall"></param> <param name="allowScriptAccess" value="always"></param> <param name="base" value="http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/"></param>'>http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/"></param> <embed src="http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/CCT2.0_controller.swf" quality="high" bgcolor="#FFFFFF" width="360" height="554" type="application/x-shockwave-flash" allowScriptAccess="always" flashVars="thumb=http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/FirstFrame.png&containerwidth=360&containerheight=554&showstartscreen=true&showendscreen=true&loop=false&autostart=false&color=1A1A1A,1A1A1A&thumb=FirstFrame.png&thumbscale=45&content=http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/CCT2.0.mp4" allowFullScreen="true" base="http://content.screencast.com/users/TonPlomp/folders/Default/media/4a988906-a72a-41f4-a978-35e68c0f2d20/" scale="showall"></embed> </object>
The Code Capture Tool rocks. :thumbup1: I love it. :wub:.  The video was a great touch, too.
Just to be clear (because I can't test it) folks will be able to drag a snippet made with the CCT in LV 8.6 to a LV 2009 BD?  I'm wondering when CCT 3.0 will come out, with the ability to extract the code from a snippet in pre-2009 versions...  :unsure:
Thanks
  Quote
Yes you will, I have created a snippet on Linux 8.2 and imported on Windows 2009
  Quote
Shouldn't be too hard (yours to try), but the code is embedded inside a PNG tag as a saved VI, just open up and dump like a merge VI.
Ton
Here's a LabVIEW 8.6 VI that takes a path to a snippet-embedded PNG file and creates a snippet.vi in the same folder.  I'm not happy with the way I did it; it works, but I have a feeling that there's a more elegant method.  The next thing I'd like to try is to make a JKI RCF plugin that converts a PNG on the BD into code.  It would be nicer to be able to have LabVIEW respond to a PNG being dropped onto the BD; do you know how I might do that?
Hey folks!  This picture is a Snippet made with the Code Capture Tool in LV 8.6!  :thumbup1:
GetSnippet.viFetching info...
I am wondering how your code actually works since the snippet is embedded in a 'niVI' chunk preceded by the chunk size.
The snippet is created in 'user.lib\_Code Capture Tool\CCT Class\Software\Methods\Private\Snippet\CCT_Snippet__CCT.vi'
Here is a screenshot of the VI that creates the chunk:
And I think this code should get the actual snippet (tested):
Ton
  • 3 weeks later...
Here's a LV7.1 llb that will extract a snippet made with the CCT, and a snippet to test it with.  Put the llb into [LabVIEW]\project and restart LabVIEW to use it.  Put the snippet in a BD, select it and click Tools -> GetCCTSnippet.  Now all I need is for folks to make snippets instead of screen shots...
GetCCTSnippet71.llbFetching info...
  • 8 months later...
Ton,
The latest version has two issues that I saw:
  1. There's a breakpoint in the installer.
  2. I don't see the snippet image in the CCT unless I drag the empty preview area.
I tested a snippet from LV2010 to 8.2. It worked beautifully. Thanks for the good work.
Jim
  • 1 month later...
I have just installed the code capture tool opg package in LV8.5.1 and I am having a problem getting it to capture a selected case in the block diagram of a particular VI. Here is a screen capture of the code-capture front panel. Notice that the Block Diagram options are disabled (grayed out). I am able to get the block diagram selection to work with other higher level VI in this project.
Thanks in advance for any help you can provide
Jim Cardinal
The block diagram options should be unavailable if the BD is inaccessible. This can happen if the BD has been removed or if the VI does not have one (like a global VI or a control) or if the VI's BD is locked.
Looking at the code, it looks like there is one bug there - it compares the lock state to 2 or greater which, according to the help, would prevent the BD from being accessible even if it was only locked. The comparison should be changed to greater than 2 (which should only apply to a password protected BD). If this is important to you, you can change it now, as the code is open source.
Thanks for the reply. The VI in question is a subVI of a password protected higher level VI. Other that removing the password protection, is there a way to access the BD of the subVI with the code_capture tool?
Jim Cardinal
I don't think that being inside another PW'd VI should have affected the VI you're trying to view, so I'm assuming the actual VI is also PW'd.
We did discuss allowing the user to unlock the VI from the CCT at one time, but I was against it, because I didn't want to overload the CCT with more functionality. I believe you should be able to use the CCT to capture the BD if you simply unlock the VI before calling the CCT. If you want to automate this, the VI class should have a method you can call to unlock the VI, but you'll need to provide the password.
