george seifert Posted May 9, 2009 Report Share Posted May 9, 2009 I've run into this bug a few times now so I think it's real. I'd appreciate it someone could run the simple attached VI (LV 8.6.1) and let me know if you get the same error. I was getting this with LV 8.6.0 also. The problem is that the Actual Start value (Current Iteration Timing from the Left Data Node in a timed loop) occasionally reports a huge value (18446744069414584318 or something like that). It seems worse when there are two timed loops running. There doesn't seem to be any consistency in when it happens so you may have to let the VI run awhile before it happens. In my tests though it always happened within a couple of minutes. Thanks, George Download File:post-2786-1241793290.vi Quote Link to comment
PaulG. Posted May 9, 2009 Report Share Posted May 9, 2009 I ran it for over 5 minutes with no error. Quote Link to comment
crossrulz Posted May 9, 2009 Report Share Posted May 9, 2009 I ran it all through lunch with no error. I am also using LabVIEW 8.6, so it's not exactly the test you are looking for. Quote Link to comment
george seifert Posted May 9, 2009 Author Report Share Posted May 9, 2009 Thanks guys for trying it out. I don't know what's different about my system. I have two different apps built into executables that have shown this problem on several different PCs so I know it's real. I've reported it to NI so we'll see if they can reproduce it. George Quote Link to comment
huotom Posted May 10, 2009 Report Share Posted May 10, 2009 QUOTE (PaulG. @ May 8 2009, 10:54 PM) I ran it for over 5 minutes with no error. There is no error appears. OS: WinXP PF: LV 8.6.1f1 Quote Link to comment
george seifert Posted May 12, 2009 Author Report Share Posted May 12, 2009 NI has confirmed this bug. They had to let it run over the weekend so it's not surprising that no one else here saw the problem. I don't know what it is about my system that I see the problem so quickly. Just lucky I guess. George Quote Link to comment
jackmax Posted May 15, 2009 Report Share Posted May 15, 2009 I have run the VI, There is no error Quote Link to comment
