Issue with text into Picture Control
Hi all,
I'm upgrading some code from LV 7.1 to LV 8.6 and have an issue with texts into a Picture Control.
In LV 7.1, this code
post-7452-1242134180.png?width=400
will give this if I print to à pdf file and zoom on the pdf
post-7452-1242134196.jpg?width=400
In LV 8.6, the same code will give this...
post-7452-1242134214.jpg?width=400
If I zoom even more on the pdf generated with LV 7.1 it appears that the text is vectorial and always appears very nice, but it seems not to work in LV 8.6.
Anyone knows how I can fix that?
I checked my LV option for printing in 7.1 and 8.6, they are similar.
QUOTE (Antoine Châlons @ May 12 2009, 09:17 AM)
Hi all,
Q1) If you explicitly define the font in both cases, do you still see the same thing?
Q2) Do simple lines show up the same way when exported and zoomed?
Just trying to narrow it down,
Ben
QUOTE (Antoine Châlons @ May 12 2009, 10:01 AM)
I would suspect you are going to have to hound NI for an answer to that Q. Between LV 7.1 and * they added the ability to zoom a picture (I think, don't quote me) so that change may be playing a part in what youare seeing.
Ben
QUOTE (neBulus @ May 12 2009, 04:12 PM)
Ben
Thanks for that Ben, I'll ask support from NI.
The issue has been reproduced by NI support engineer and is being investigated.
Apparently a change has been made between LV 8.0 and 8.20. I'll keep posting as soon as I recieve info fron NI.
Reference#8637-B43187
  • 2 weeks later...
Latest information received from NI support in Germany :
  1. issue has been sent to R&D (Austin) for further investigation
  2. it is still not clear if the change of behaviour was intentional (LOL, the eternal "bug or feature?")
  3. a "quick fix" is not be expected in a short term futur
