Antoine Chalons Posted May 13, 2009 Report Share Posted May 13, 2009 Hi all, I'm upgrading some code from LV 7.1 to LV 8.6 and have an issue with texts into a Picture Control. In LV 7.1, this code will give this if I print to à pdf file and zoom on the pdf In LV 8.6, the same code will give this... If I zoom even more on the pdf generated with LV 7.1 it appears that the text is vectorial and always appears very nice, but it seems not to work in LV 8.6. Anyone knows how I can fix that? I checked my LV option for printing in 7.1 and 8.6, they are similar. Quote Link to comment
Grampa_of_Oliva_n_Eden Posted May 13, 2009 Report Share Posted May 13, 2009 QUOTE (Antoine Châlons @ May 12 2009, 09:17 AM) Hi all,I'm upgrading some code from LV 7.1 to LV 8.6 and have an issue with texts into a Picture Control. In LV 7.1, this code will give this if I print to à pdf file and zoom on the pdf In LV 8.6, the same code will give this... If I zoom even more on the pdf generated with LV 7.1 it appears that the text is vectorial and always appears very nice, but it seems not to work in LV 8.6. Anyone knows how I can fix that? I checked my LV option for printing in 7.1 and 8.6, they are similar. Q1) If you explicitly define the font in both cases, do you still see the same thing? Q2) Do simple lines show up the same way when exported and zoomed? Just trying to narrow it down, Ben Quote Link to comment
Antoine Chalons Posted May 13, 2009 Author Report Share Posted May 13, 2009 QUOTE (neBulus @ May 12 2009, 03:41 PM) Q1) If you explicitly define the font in both cases, do you still see the same thing?Q2) Do simple lines show up the same way when exported and zoomed? Just trying to narrow it down, Ben R1 : changing the font or the size (or both) doesn't solve the issue. R2 : the line (I used the "Draw Multiple Lines.vi") look much nicer when generated in LV 7.1, just like for the text it seems to be vectoriel, see below : To be clear: I print the front panel to a pdf file and then zoom the pdf file. The images below are screenshots of the generated pdf file with a zoom at 1600%. generated with 7.1 generated with 8.6 Thanks for helping out Quote Link to comment
Grampa_of_Oliva_n_Eden Posted May 13, 2009 Report Share Posted May 13, 2009 QUOTE (Antoine Châlons @ May 12 2009, 10:01 AM) R1 : changing the font or the size (or both) doesn't solve the issue.R2 : the line (I used the "Draw Multiple Lines.vi") look much nicer when generated in LV 7.1, just like for the text it seems to be vectoriel, see below : To be clear: I print the front panel to a pdf file and then zoom the pdf file. The images below are screenshots of the generated pdf file with a zoom at 1600%. generated with 7.1 generated with 8.6 Thanks for helping out I would suspect you are going to have to hound NI for an answer to that Q. Between LV 7.1 and * they added the ability to zoom a picture (I think, don't quote me) so that change may be playing a part in what youare seeing. Ben Quote Link to comment
Antoine Chalons Posted May 13, 2009 Author Report Share Posted May 13, 2009 QUOTE (neBulus @ May 12 2009, 04:12 PM) I would suspect you are going to have to hound NI for an answer to that Q. Between LV 7.1 and * they added the ability to zoom a picture (I think, don't quote me) so that change may be playing a part in what youare seeing.Ben Thanks for that Ben, I'll ask support from NI. Quote Link to comment
LAVA 1.0 Content Posted May 13, 2009 Report Share Posted May 13, 2009 One question what kind of printer driver do you use? Ton Quote Link to comment
Antoine Chalons Posted May 14, 2009 Author Report Share Posted May 14, 2009 QUOTE (Ton @ May 12 2009, 04:19 PM) One question what kind of printer driver do you use?Ton In both cases we use http://www.fineprint.com/' rel='nofollow' target="_blank">FinePrint pdfFactory v1.43 to print our file into pdf, we've been using it for a few years now, this is the first time we have quality issues. Quote Link to comment
Antoine Chalons Posted May 21, 2009 Author Report Share Posted May 21, 2009 The issue has been reproduced by NI support engineer and is being investigated. Apparently a change has been made between LV 8.0 and 8.20. I'll keep posting as soon as I recieve info fron NI. Reference#8637-B43187 Quote Link to comment
Antoine Chalons Posted May 30, 2009 Author Report Share Posted May 30, 2009 Latest information received from NI support in Germany : issue has been sent to R&D (Austin) for further investigation it is still not clear if the change of behaviour was intentional (LOL, the eternal "bug or feature?") a "quick fix" is not be expected in a short term futur Quote Link to comment
