JayKay Posted September 9, 2009 Report Posted September 9, 2009 Hi Friends, Recently i bought a PC which is having only one PCI slot. Others are PCExpress slots. But i want to use few PCI compatible NI hardware same time. Is there any hardware available in tha market like a adopter which can give more PCI Slots for my computer? otherwise any idea how to convert PCExpress slot to PCI slot? Thanks. Regards, Jai Quote
Tim_S Posted September 9, 2009 Report Posted September 9, 2009 I use industrial PCs specifically because I get 14 PCI slots (and occasionally I use all the available space), so my first suggestion would be to use a different PC. I've not looked, but I wouldn't be surprised if there was a bus extended to a passive backplane available; you may wish to look for such. If you've not bought your cards already, a PXI chassis with a MXI extended may be an option for you. Tim Quote
Anders Björk Posted September 9, 2009 Report Posted September 9, 2009 Magma has boxes for PCIExpress to PCI. http://www.magma.com/index.html Quote
ShaunR Posted September 9, 2009 Report Posted September 9, 2009 Hi Friends, Recently i bought a PC which is having only one PCI slot. Others are PCExpress slots. But i want to use few PCI compatible NI hardware same time. Is there any hardware available in tha market like a adopter which can give more PCI Slots for my computer? otherwise any idea how to convert PCExpress slot to PCI slot? Thanks. Regards, Jai NI also do PCIe cards. Quote
Neville D Posted September 9, 2009 Report Posted September 9, 2009 NI also do PCIe cards. Also, if I remember correctly, some of their PCI cards might fit in a PCI-Express slot as well. Check the documentation. Neville. Quote
Black Pearl Posted September 9, 2009 Report Posted September 9, 2009 I also go with Industrial Computers - apart from PCI - I rely on good old RS232. I would say, that is a bit the professional way of dealing with that issue (industrial computers have other advantages as well, but cost more I guess). For hobby/low budget I would head for the USB devices (I think they also safe you some cabeling costs). And another solution for the geeks: use an old PC with PCI, connect it via Ethernet to a modern PC. Have the DAQ part running on the old PC and fetch the Data from these small VIs via VI Server and do the analysis on the new one. Felix Quote
JustinThomas Posted September 15, 2009 Report Posted September 15, 2009 There are lot of PCI extender options available. Checkout the attached link for details on PCI/PCIe extender options from a popular brand http://www.adlinktech.com/solution/tech_forum.php?file=measure/20071219.htm&gclid=CLTRsaXl8pwCFUUwpAodBF-ciw Quote
