[CR] UI Tools addon: Control class
hmm. Looks like it was meant to remove previous releases of Control addon class but I might have forgotten to change the namespacing. This looks like a self-conflict.
Can you let me know which version you are using? I don't have 2011 installed as your profile suggests, but I'll try to reproduce the issue on a newer version and come up with a new package or a solution.
Hi Francois,
FYI
When I installed the four expansion packs the Glassweb and System Styles had all buttons present, but there were a number missing in each of the sub-palettes for the Outlook and Vista Styles - for example....
Chris
Hi Francois,
Yes it did fix it! (I'm using 2014 right now, but still 2011 in general)
I had to restart VPIM to get rid of the conflict icon though. But now everything looks good! Thanks
Thanks Francois for fixing up the missing Outlook buttons. You got 99.99% of them fixed I just found one button missing in the Media Palette called "outlook_video.ctl"
Chris
  • 3 years later...
After installing the latest version with VIPM on my LabVIEW 2018 SP1 32 bit, every time I try to run LabVIEW, it crashes.
I deleted the folder C:\Program Files (x86)\National Instruments\LabVIEW 2018\project\UI Tools and then no more crash.
Any idea?
Ha, I think I found the issue, I should have let VIPM mass compile the package after installing it.
I had to move "Create control.vi" out of the C:\Program Files (x86)\National Instruments\LabVIEW 2018\project\UI Tools\Control Generator, open it, mass compile it place it back and now it all works fine.
  • 1 month later...
Thanks Antoine for your workaround to fix the Labview crash after installation of the 1.4.0.15 version on also LV2018 SP1. Your tip just helped me, too.
I had Labview crashing also with the previous 1.3.0.12 version installation on LV2015 SP1, there for some reasons it helped to install all required packages package by package with the JKI VIPM.
Apart from that recent installation issue the Control class UI Tools addon is a fantastic tool, and we use it frequently. Thanks François!
  • 6 years later...
