[CR] UI Tools addon: Control class
hmm. Looks like it was meant to remove previous releases of Control addon class but I might have forgotten to change the namespacing. This looks like a self-conflict.
Can you let me know which version you are using? I don't have 2011 installed as your profile suggests, but I'll try to reproduce the issue on a newer version and come up with a new package or a solution.
Hi Francois,
FYI
When I installed the four expansion packs the Glassweb and System Styles had all buttons present, but there were a number missing in each of the sub-palettes for the Outlook and Vista Styles - for example....
Chris
Hi Francois,
Yes it did fix it! (I'm using 2014 right now, but still 2011 in general)
I had to restart VPIM to get rid of the conflict icon though. But now everything looks good! Thanks
Thanks Francois for fixing up the missing Outlook buttons. You got 99.99% of them fixed I just found one button missing in the Media Palette called "outlook_video.ctl"
Chris
  • 3 years later...
After installing the latest version with VIPM on my LabVIEW 2018 SP1 32 bit, every time I try to run LabVIEW, it crashes.
I deleted the folder C:\Program Files (x86)\National Instruments\LabVIEW 2018\project\UI Tools and then no more crash.
Any idea?
Ha, I think I found the issue, I should have let VIPM mass compile the package after installing it.
I had to move "Create control.vi" out of the C:\Program Files (x86)\National Instruments\LabVIEW 2018\project\UI Tools\Control Generator, open it, mass compile it place it back and now it all works fine.
  • 1 month later...
Thanks Antoine for your workaround to fix the Labview crash after installation of the 1.4.0.15 version on also LV2018 SP1. Your tip just helped me, too.
I had Labview crashing also with the previous 1.3.0.12 version installation on LV2015 SP1, there for some reasons it helped to install all required packages package by package with the JKI VIPM.
Apart from that recent installation issue the Control class UI Tools addon is a fantastic tool, and we use it frequently. Thanks François!
  • 6 years later...
On 2/27/2026 at 4:06 AM, Vandy_Gan said:
Francois,
Is it possible to generate an application that runs in a runtime environment only?
First, attaching your question to random (multiple) threads is not a very efficient way of seeking help.
I'm not sure I understand your question correctly. But there is the Application Builder, which is included in the Professional Development License of LabVIEW, that lets you create an executable. It still requires the LabVIEW Runtime Engine to be installed on computers to be able to run it, but you can also create an Installer with the Application Builder that includes all the necessary installation components in addition to your own executable file.
Vandy, judging by the other threads where you posted, it seems you want to generate buttons with icons dynamically in an EXE. (my understanding)
Although you might succeed in creating VI Controls through VI Server from a build executable, you will need LabVIEW development on the computer and you will not be able to modify the front panel of your EXE unless you script your buttons on an unloaded VI and then load it dynamically in your EXE`s subpanel. It defeats the purpose of the compiled binary in the first place.
All the toolkits you are looking at are meant to help you generate libraries of reusable assets that meet your style and needs, but that won't help you in a dynamic UX. For that, the only thing I know works (well enough) in LabVIEW is to use a picture control, possibly wrapped into a QControl if you are thinking big.
Francois,
Indeed, as you mentioned, I came across a Chinese video while surfing the internet earlier. It demonstrated examples of generating buttons in both development environment and runtime engine. The video link is provided below. I'm not sure if you can see it
https://www.bilibili.com/video/BV1MhzNYvEiw/
5 hours ago, Vandy_Gan said:
Francois,
I can't understand Chinese and the video only shows some highlights, not how it works. My assumption it that they might use Windows Controls. It's a possibility but the effort needed to create a toolkit like that for use in LabVIEW is ENORMOUS. If it exists and you really absolutely want to do this for any price, buy the toolkit no matter how expensive. Trying to do that yourself is an infinite project! Believe me!
On 3/4/2026 at 6:36 AM, Vandy_Gan said:
RTK LVButtonGX Installer.exeThis is the installation package
Are you seriously expecting anyone to install a random executable on their system from an unknown publisher, provided by an anonymous person on the web, where one can't even get a proper link in Google to the actual company page?
Sorry, but anyone doing that should not be allowed near 5m of a computer system!
Edited by Rolf Kalbermatter
  • Haha 2
