jgcode Posted August 28, 2010 Report Posted August 28, 2010 Name: New Accessors Submitter: jgcode Submitted: 28 Aug 2010 File Updated: 03 Jan 2011 Category: *Uncertified* LabVIEW Version: Not Applicable License Type: Other (included with download) New Accessors v1.0 Copyright © 2010, Jonathon Green; JGCODE All rights reserved. Author: Jonathon Green LAVA Name: jgcode Contact Info: Contact via PM on lavag.org LabVIEW Versions: LabVIEW 2010 only Dependencies: None Description: This package contains code posted on NI Forums by NI that applies a fix to the New Accessors folder. All VI passwords have been removed! This fix is for LabVIEW 2010 only. This package will install files to the labVIEW 2010\resource\Framework\Providers\LVClassLibrary\NewAccessors folder On uninstall the original files will be re-installed. See here and here to view original document and post by AQ. Installation and instructions: Install package using VIPM. Examples: No examples. Known Issues: No known issues. Acknowledgements: Aristos Queue Version History (Changelist): 1.0-1 2010 08 28 - New (): Initial public release of the code (LabVIEW 2010) License: Copyright © 2010, National Instruments Support: If you have any problems with this code or want to suggest features: please go to lavag.org and navigate to LAVA > Resources > Code Repository (Certified) and search for the New Accessors support page. Distribution: This code was downloaded from the LAVA Code Repository found at lavag.org Click here to download this file Quote
Aristos Queue Posted August 28, 2010 Report Posted August 28, 2010 You should change the title. This covers both New Accessors and New Overrides. Quote
jgcode Posted August 28, 2010 Author Report Posted August 28, 2010 You should change the title. This covers both New Accessors and New Overrides. Sorry, the name was from the Installation Folder. The description in the package contains the text which covers your NI Document. How about you tell me what you want it called - and I will change it to that? Quote
jgcode Posted August 30, 2010 Author Report Posted August 30, 2010 Maybe named after the top level .lvlib would be better? Quote
ShaunR Posted August 30, 2010 Report Posted August 30, 2010 Maybe named after the top level .lvlib would be better? How about "Eric"? That's a good solid name. Quote
Black Pearl Posted August 30, 2010 Report Posted August 30, 2010 And with localisation to Erich, Erik... Felix Quote
jgcode Posted August 30, 2010 Author Report Posted August 30, 2010 How about "Eric"? That's a good solid name. I like it - my Dad is named Eric Quote
Daklu Posted August 31, 2010 Report Posted August 31, 2010 How about "Eric"? That's a good solid name. "Sonja" is much more fitting for something this sexy. Quote
jgcode Posted August 31, 2010 Author Report Posted August 31, 2010 "Sonja" is much more fitting for something this sexy. Quote
jgcode Posted September 1, 2010 Author Report Posted September 1, 2010 Seems there was an issue with downloading the files. I have just fixed it and you can now download this package (or zip). Quote
