Automatic code execution on Project load
Hi all,
I recently found some interesting code at the german labviewforum.de.
Basically it looks like a not so funny prank.
LV-Chat
The included project starts an embedded VI after opening the .lvproj.
Warning:
I am not 100% sure if this is all harmless. As far as I can tell it displays some dialog boxes, writes a virus test pattern and opens notepad.exe with a temp file.
My current guess is, that the combination of a Xcontrol and the way LV loads lvclasses leads to the execution of the Init ability at load time.
I tried to copy the concept in the attached file xcontrol+lvclass.zip. But the Init.vi in my project doesn´t get executed before I manually open a VI that uses the XControl (this is of course the expected behavior).
Anyone has an idea what else is necessary to get this auto-execution at load time?
I was very scared as I opened the Chat project the first time.
The possible usage for distribution malicious code is really scary. On the other side, automatic launching of some helper VIs when I open a project might be a nice feature (e.g. forced update file state when working on a slow connection to a Perforce server, where LV-SCC integration is sometimes just unusable)
Thats why I want to understand how this works and what the load triggers are.
After I saved all VIs in the nutshell (they were not flagged as recompiled/edited) the auto-execution did stop in my machine at work. The .lvclass and .lvproj files didn't change, the VIs of course did. rolleyes.gif
