Calculate average and Max from csv file
Hii VI folks,
I have to ask two Questions.
1. I am frusty.gif to fetch the values from csv file and want to calculate the average, max and min.
2. Lets say i have 100 readings in csv file and i want to calculate Max, min and average from 10-90readings. the reason behind this, i want to skip (0-10 and 90-100 readings) the constant values from beginning and at the end.
Thanks
-Hasan Karkra
Read the values into an array (sounds like a 1D array) then use the array subset feature to get an array which has an offset of 10 but getting the rest. Then get a subset of that which has offset of 0 but length is array size minus 10. This will give you an array of 80 values. Perform operations on these 80. There is a maximum and minimum array function, and I think average as well.
If you post what you have so far we could help a little better. If reading your CSV is the issue, post an example of the CSV as well.
I want to create a VI which fetches the information from .csv file and at the end GUI comes up with Avg, Man and Min values. This is my short term goal or project. I am beginner in VI. So, by following this fact am tiring to do this task step by step.
  • Fetch information from CSV file.
  • By using array function, calculate the required parameters.
  • Output pops up in GUI.
My approach is this. Sorry to say, i don't have VI file to upload.
You seem to have broken down what you need well. Have you looked through the pallet at what primatives and VIs are present? Looking through the File and Array palletes should make what you need to do obvious.
I expect you're going to get limited help until you've shown you've tried to do something especially as this sounds like a homework assignment.
Tim
post-18502-0-75886300-1291311776_thumb.jThanks for your group support. Here is the working VI.
This doesn't look like it should work since you have a race condition on your Max Index(es). You really should use wires instead of the value property node. On another side note: locals are better than property nodes for getting/setting a value from a control/indicator, but a wire is best.
