labview with fpga
hi.. guys
i am doing a project in labview ...( HMI) which controls the machine.. user interface..
now what i need is i want to communicate the pc labview with FPGA  some standard communication  protocol...
it should be faster.... (because i want to do frame grabbing the raw data)
reliable, less hardware , multi slave interface... less communication error... etc so kindly guys give some good suggestions...
Are you talking about using LabVIEW FPGA talking to a host LabVIEW program running on Windows? Or are you talking about a generic FPGA talking to a host LabVIEW program running on Windows?
If you are programming an FPGA with LabVIEW, talking to your Windows based LabVIEW program is very easy using a DMA buffer. If you have the FPGA toolkit for LabVIEW installed, then you should have the examples in Example Finder, that shows how to setup and use a DMA buffer of data. Just search for DMA.. The other normal way of getting data from LabVIEW FPGA to a host us from reading the indicators on the front panel of the FPGA code. This is slower and is a single shot read so I don't think this is what you are looking for.
If you are talking about a generic FPGA talking to LabVIEW, I have no input because I've never needed to do that.
thanks for ur response sir
i am looking for
some standard communicatons like CAN , USB ,RS485 ETC..
Edited by pravinspidy
There are FPGAs out there with built in UARTs (or at least an easy interface to one). Using this, I have communicated with FPGAs in our UUT (unit under test) using a simple RS-232 serial port. Other option I have personally done is RS-422. I'm not sure what kind of data rate you need, but these are simple to control (using VISA) and the hardware is cheap (RS-232 port often built into a motherboard).
thanks for ur reply sir
  sir actually i tried with fpga through  Rs232 i am not that much familiar with vhdl language.. anyway i was done a code for uart referring some example code from.. opencores.com.  still now iam struggling with code....
data rate is 115200bps
I'm not a VHDL programmer either. I know just enough to be able to read it...maybe. I just had to interface with other people's FPGAs and microcontrollers that are in the units I had to test. RS-232 was the bus of choice and it proved to work well.
