Please help, Convert this string format to number
I send some command via RS232 to my machine and the machine sent me back with a number "40" display in normal display in my attatched picture. I tried to use the string convert to num tools but there is nothing happen.
I wondering with it, then I try displaying the string in different way as in attached, code display and hex display.
I want to get the string "40" to change it to number, how can I get it? please help
Thank you in advance.
Not totally sure I have understood your question correctly by string convert to number tools do you mean Scan From String ?
Scans the input string and converts the string according to format string.
Use this function when you know the exact format of the input. The input can be string, path, enumerated type, time stamp, or numeric data. Alternatively, you can use the Scan From File function to scan text from a file. The connector pane displays the default data types for this polymorphic function.
Would help if you showed you block diagram
Thank you. I have already done with it. with this solution.
What version are you using? How did you do it before? As far back as at least 8.6 (I don't currently have older to check), all you should have needed is the Decimal String to Number. It will find the number even with all of the white space.
There is a vi in the examples called Extract Numbers.vi. It's perfect for this application. It takes a string as an input and converts it to an array of numbers. Then you simply index the array to extract the number you need. It's really useful when your string contains more than one number.
You can dig it up through the Example finder, or here:
..\National Instruments\LabVIEW xxxx\examples\general\strings.llb\Extract Numbers.vi
