Team LAVA still active?
drjdpowell
I can't speak for the "Team LAVA" because I was not involved, but I know for a fact that Mark is still very active and personally goes through each submission to the CR when something is submitted.
Hi James,
It depends on how you define "Active".  There hasn't been a Team LAVA submission to the LabVIEW Tools Network in quite a while, but that doesn't mean the movement is dead.  If you have something you'd like to submit, by all means please do.  You are also welcome to submit it under the LAVA name (assuming you follow the guidelines laid out by jgcode) or you can submit it under your own company (assuming it follows the Compatible With LabVIEW guidelines).
Let me know if you have any questions about the process.
David
