Team LAVA still active?
drjdpowell
Hi James,
It depends on how you define "Active".  There hasn't been a Team LAVA submission to the LabVIEW Tools Network in quite a while, but that doesn't mean the movement is dead.  If you have something you'd like to submit, by all means please do.  You are also welcome to submit it under the LAVA name (assuming you follow the guidelines laid out by jgcode) or you can submit it under your own company (assuming it follows the Compatible With LabVIEW guidelines).
Let me know if you have any questions about the process.
David
