Thang Nguyen Posted April 29, 2014 Report Posted April 29, 2014 (edited) Hi, I would like to ask if any have experiment with Omega load cell LCMFL series? By some reasons, I cannot get any response from the load cell. So I need help. In my project I have a load cell LCMFL 20N connect with NI 9237 card. I set it up with full bridge (verify with customer service), internal, 5 V excitation. The scale is 10N 1mV/V. I cannot get any response from it. Then I tried to connect it with a 5VDC power supply and use multimeter to measure but the response signal is not changed either. So I wonder if I do anything wrong with the wiring or not. Regards, Thang Nguyen Edited April 29, 2014 by Thang Nguyen Quote
pallen Posted May 1, 2014 Report Posted May 1, 2014 Hello Thang, The documentation found here: http://www.omega.com/Pressure/pdf/LCMFL.pdf seems to indicate that these load cells require exitation voltage on the Red and Black wires. This is typical of most load cells. I can't say for sure why your app is not working. Have a look at the following documentation and check your wiring. http://digital.ni.com/public.nsf/allkb/D02125BF0BFC6130862576650001F14C http://sine.ni.com/psp/app/doc/p/id/psp-168/lang/en Quote
Thang Nguyen Posted May 15, 2014 Author Report Posted May 15, 2014 Pallen, It turns out my censors are fired by my coworker. We ordered a new one and it works as it suppose to be. Thanks all! Quote
