[CR] SET Localization Toolkit
Some important things to note:
- The source posted is actually for LabVIEW 2013.
- Version 0.3 is an alpha release. Expect to encounter bugs.
- Make sure that you add "UseUnicode=True" to the LabVIEW.ini file and restart LabVIEW before running the program..
- To start the program, run the "Launcher.vi" located in the "SET Language Editor" folder.
Strings supported as of version 0.3.1:
Front Panel
- Custom Title
Front Panel Decoration Text
- All
Block Diagram String Constants (Not located within a structure)
- Extracted if Label Visible
- Labeled String Constants within Labeled Clusters will be extracted.
- Block Diagram Array Strings currently not supported.
All front pane Controls
- Visible Captions
- Tip Strips
Boolean Controls
- Visible Boolean Text
Ring Controls
- Item Strings
String Controls
- Default Value
Run-Time Menus
- Item Name if Item Tag doesn't start with APP
Edited by Porter
  • 1 month later...
  • 3 months later...
Thank you for making this toolkit free for us all to look at.  I was looking into making a similar (but much less sophisticated) toolkit.
A possible update:  The Add Language popup will only let you select from Languages already populated by the developer, ie you cannot "add" a language by typing the language while using the toolkit.  It looks like I would need to edit the Language Selector.ctl to add more languages, then reopen the toolkit in LabVIEW to add the language to my project.
I will look into adding this feature. The reason why I made a static language list was because I link the language to its associated code page. I suppose that it would make more sense to store this information in a config file that the user can modify.
  • 1 month later...
I'm currently adding support for 1D string array controls and constants. I will look into moving to LV 2012 after that.
  • 2 weeks later...
Version 0.4.0.1 has a LV2013 and LV2012 package available for download.
If you are running LV2013 or higher, please use the LV2013 package. I haven't had time to thoroughly test the LV2012 package.
  • 3 years later...
  • 1 year later...
This toolkit is for edit-time language switching. I don't see why it wouldn't work. But I don't have the hardware or dev environment licenses to test it. Donations are welcome ;)
  • 1 year later...
I click new project, but the window suddenly disappeared.I try to find out what cause it, and finally I find in the vi "Get All VIs from Project" will bring out error code "43" and "1026".I can clear these errors and it works well.But I don't know the root reason.If guys have the problem same with me, you can try it.
Expand
Addition to this, I find this work abnormal on Chinease chanslation. After try, don't open my target *.lvproj first, but open the set tool window first, it works well. I didn't try open the target *.lvproj when I want to use this tool afterwards.
From your project image you seem to have many conflicts. It's likely that you are picking up another version or VI's in a different location in your project.
You need to resolve the conflicts before any troubleshooting can occur.
  • Like 2
